Got started on the enclosure today. Didn't get much done, spent most of the day changing everything. I had to scale it down to 20 cubes due to not enough room for the needed port area. I'm still just a little shy of what Fi recommends. I ended up with 11.94 square inches per cube @ 32 hz or have the option to pull the port and have 13.35 square inches per cube @ 47.5 hz.
You need more port area mate... I don't see you getting good results with less than 12in per cube.
I don't have the room. The front of the enclosure is 47.25" wide X 41.25" high with 1.5" walls and 4 18.5" subs. I've done the math all day. See what you can come up with, maybe I'm missing something.
Should have done 15's instead. Didn't you take measurements first before you bought the subs so you would know what fit? 4 15's in a proper enclosure will get a lot louder than 4 18's in one that's too small
TDH FTW !!!
Could you possibly do aeroports?
I don't know why I couldn't. I've looked at them online but I'm not familiar with them. How do calculate port area on a 6"? I was taking diameter x pie and coming up I need 13, so I don't think I calculated right.
Area of circle is pi times radius squared I believe. Soo 3.14x(3x3)= 3.14x9=28 and some change of port area.
Aeroports are more efficient and use up less space than slot ports, but they are more costly. I'm using 4 6" aeros in my wall with 2 18s in 11cubes, and that ran me $133 as opposed to making a slot port with MDF you'd already have lieing around.
To start I was going to run two 18's. I took measurement figuring on 3/4" walls and decided to order two more 18's. After I ordered them I thought I should double the wall thickness and go 1 1/2". With the 3/4" walls I would have 15.30" square inches per cube. Which would be the lesser of 2 evils, 3/4" walls or 11.94" square inch per cube of port area?
No point in having a larger port if the box is going to blow apart. I would never consider using on 3/4" MDF for 4 18s on 12kw...
I still say look into aeroporting, you may be able to figure something out that works for you.
