Okay I'm trying to plan out my big 3 so that when my 1/0 wag comes in this week I can cut all the lengths quick and put the terminals on and connect it! But i can't seem to find where the engine ground on my 2001 dodge ram 2500(cummins diesel)is, does anyone know where Chrysler ran the engine ground on these trucks? And if I can find it, would it be okay to run a run of 1/0 wag from the alternator cover to my ground on the battery? Also this truck has two batts, should I do the big 3 on the whole setup or just the batt that connects directly to my alt? Thanks
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
Bump
so far...
You can run the engine ground from any bolt that connects to the general body of the engine. If the alternator cover is a solid piece of metal attached to the engine then it would work for a ground. You don't have to do it but it would help with charging if you connect the positives and negatives of the two batteries
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
this ^ ^ ^ ^
on mine i have two off the engine, just find urself a nice bolt with clear metal and it will work
Ok good deal, and I don't even have to connect it to the battery ground right? I can just ground the engine to the frame from what I understand?
so far...
1st wire, neg on battery to a bolt with clean metal under the hood
2nd wire, engine to another bolt with clean metal
3rd wire, pos on battery to alternator
now on the wire on the alternator U can run a fuse, IMO i never do but its fine to do it either way. with fuse its just the safer way
So if the engine wire is currently going to the battery.. you can disconnect it and ground the engine wire to any good ground location? It does have to be the battery? I dont get how that helps the Amp flow, im confused :(
Alright cool, and one last question lol
I have a left over 7ft strand of cadence 1/0 awg ( they say it's copper, seams like cca to me) should I just run that from batt to batt piggy backed on the 4ga that already there? Would that help charge instead of replacing the original 4ga with a piece of my monster 1/0 awg? Sorry for all the questions, batteries are not my strong point although I am learning pretty quick
so far...
Posted (edited)
id leave it the way it is, its just one big circle basically
from what understand ur also grounding the alt to the car itself/chassis when grounding the engine. some alts like mine, dont have a actual bolt on the alt to ground it off so grounding the engine is the next best thing
on mine i went a bit over board:
2x-0g and 4g from neg on battery to chassis
2x-0g from engine to chassis(different spots)
1x-0g from alt to battery
4x-0g to rear batteries from alt
2x-0g from neg on battery to rear batteries :)
I learned from Derick you cant over do it, at least in Integra's that is lol
would this be after you do ur big3 or are you thinking of doing this instead of your big3
Edited by BeatBox
