Audio-Concepts Posted July 1, 2011 Report Posted July 1, 2011 Well here it goes, I dont have access to a computer so I need a little assistance in what length a 4" aeroport will give me to tune around 36hz. The outer measurements are 10"x24"x13.5" which makes it about 1.32cu ft internal! Sub is about .11 cu ft displacement so I will be right in the 1.15-1.25 cu ft requirements for ported! I also want to run as a side port so I can still keep my beauty panel! If someone could assist that would be great! Thanks, Mike Pioneer AVH480 Zapco ST5XII amplifier Stevens Audio 6.5" components (passive) Onyx Subwoofer Sky High OFC wiring
18abVFL Posted July 3, 2011 Report Posted July 3, 2011 Well here it goes, I dont have access to a computer so I need a little assistance in what length a 4" aeroport will give me to tune around 36hz. The outer measurements are 10"x24"x13.5" which makes it about 1.32cu ft internal! Sub is about .11 cu ft displacement so I will be right in the 1.15-1.25 cu ft requirements for ported! I also want to run as a side port so I can still keep my beauty panel! If someone could assist that would be great! Thanks, Mike my calcs say the box will end up being 1.06 cubes after port displacement. The box wont be wide enough to tune down to 37, the lowest tuning you'll get with a 4" port will be 38 in that box. I suggest having the port come out the front of the box (no port inside the box at all). That way your box will be 1.22cubes, and a 4" aero would only have to be 17" long for 37hz tuning 1999 Monte Carlo Sony CDX-GT34w 2 Alpine Type R 12"s in 4 cubes tuned to 35hz American Bass VFL 80.1 amp @ 1 ohm (probably doing between 1000 and 1300rms) Stock alt, Stock batt, Big 3 Upgrade Boston s55- 5 1/4s (doors) Boston s95- 6x9s (rear deck)
Audio-Concepts Posted July 4, 2011 Author Report Posted July 4, 2011 Well If I widen the box a couple inches I can still run the port internal, correct?! I forgot to figure in port displacement. This same sub a couple years ago in a 1.1 with a 6" aero hit 143 on 500 watts in a camaro! So I was hoping to do something close to upper 130's! Pioneer AVH480 Zapco ST5XII amplifier Stevens Audio 6.5" components (passive) Onyx Subwoofer Sky High OFC wiring
18abVFL Posted July 4, 2011 Report Posted July 4, 2011 Well If I widen the box a couple inches I can still run the port internal, correct?! I forgot to figure in port displacement. This same sub a couple years ago in a 1.1 with a 6" aero hit 143 on 500 watts in a camaro! So I was hoping to do something close to upper 130's! yeah you could make the box wider if possible. It will lower tuning though. 1999 Monte Carlo Sony CDX-GT34w 2 Alpine Type R 12"s in 4 cubes tuned to 35hz American Bass VFL 80.1 amp @ 1 ohm (probably doing between 1000 and 1300rms) Stock alt, Stock batt, Big 3 Upgrade Boston s55- 5 1/4s (doors) Boston s95- 6x9s (rear deck)
BJD3 Posted July 4, 2011 Report Posted July 4, 2011 Why not just make the port bend? Anti Peel and Seal...lol You may be offended by the above. Don't take it personally, I'm just abrasive. 2002 Buick Park Avenue DC Level 4 M2 12 D2 Car Audio Bargain 1600.1 Eclipse CD3200 ~2 cubes @ 34 hz. Stinger Roadkill Expert
18abVFL Posted July 4, 2011 Report Posted July 4, 2011 Why not just make the port bend? you could do that, ive never personally done it though 1999 Monte Carlo Sony CDX-GT34w 2 Alpine Type R 12"s in 4 cubes tuned to 35hz American Bass VFL 80.1 amp @ 1 ohm (probably doing between 1000 and 1300rms) Stock alt, Stock batt, Big 3 Upgrade Boston s55- 5 1/4s (doors) Boston s95- 6x9s (rear deck)
Audio-Concepts Posted July 5, 2011 Author Report Posted July 5, 2011 I have roughly 30" of width to play with, just trying to keep within the wheel wells, and height maxes out at 13.5, so I can put it under my factory cross brace, where my eq will be installed! I also dont want to be more than 10" deep, cause I have a kid and need full use of the trunk! So if anyone has an idea that could help, I would greatly appreciate it! I dont need any blueprints, just outter dimensions and port drivers side! Also thinking port towards bottom! Any help is appreciated! Pioneer AVH480 Zapco ST5XII amplifier Stevens Audio 6.5" components (passive) Onyx Subwoofer Sky High OFC wiring
