i just got done with my big three upgrade, and i still have dimming headlights. can someone give me some advise as what to do? also my subs sound the exact same, no difference in sound. i want to add some secondary batteries but not sure what to go with. prolly because im also thinking of getting a new amp. maybe a kicker zx 2500.1 and if thats the case, what secondary battery should i get?
What do you have in your vehicle now? We can't help if we don't know what you have?
04' Chevy Blazer
-Kenwood KIV-BT900, Infinity Kappa 462.9cfp's, Rockford P1653's, Subs... Ridin Stock-
big 3 only gives you a little more amperage from your alt, the bigger wire has less resistance therefore allowing current transfer easier. Also, the minuet amount of amperage gain from the big 3 wont be audible to anyone. The big 3 is also just a stepping stone in car audio, its the first thing you do to get prepared for extra batteries or an high output alternator. In your case, a second battery would probably solve your dimming issue but we would need to know what amp your currently using.
youve got too much current draw for your current ability to provide powre.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
x2
at full tilt you are probably pulling anywhere from 150-220 amps of current (if its say 2500rms on music). Stock alternators usually only product up to 105-110 amps at 1800rps or whatever they are rated to, and a lot less at idle. You really need either a second battery in the back (a decent sized battery like XS, Kinetik, C&D, Deka, etc.).
IT TAKES POWER TO MAKE POWER!!!!!
Edited by ChevyBoy95
  • Who's Online   0 Members, 0 Anonymous, 1573 Guests (See full list)
