new ground pounder.
hey guess i think im a ground pounder? hah, i got 2 15" RE SX's on 1700rms ( for now ) in a 8.2cube box tuned to 33hz, im going to invert my subs once i get new wiring to hopefully lower the tuning a bit. but i basically wanted to know of any tips to hit harder/lower, im going to hopefully buy an AQ2200 to replace my hifonics brz2400.1 and run it at .5 ohms, im going to get a bigger battery and perhaps a new alt, so i just need some tips, im not into the burps , but my first comp is next month and id like to put up some 145+ on a daily system would be sweet for a first comp lol
Driving my 2008 Dodge Ram 2500 MEGA cab with the 5.7 hemi.
Audio: Two 10" Alpine Type R's ( 1000rms models )
Hifonics BRZ 2400.1D @ .5 ohm
Two Kinetic 1400 batteries ( soon to have XS power under hood )
Tsunami 1/0 Awg wire throughout truck.
Stock Infinity 7 speaker system ( Junk ) soon to be replaced, probably all Alpine.
Exterior: 17"Dick cepek rims with 33" Toyo MT tires
Bushwacker fender flares
Magnaflow true duel exhaust
LED tail lights with Projector headlights
Plasti-dip fun coming soon!
Highy doubt you'll hit a 145 on daily with the current setup mate, sorry to be a ball crusher. Think a ground pounder is someone with a non walled setup hitting 150+ on music. You'll get there eventually 8)
:rofl:
:wub: N8.
No homo...unless you want there to be. :orly3::ehh:
well you probably wont hit that tuned at 33hz especially if you want to invert and go even lower? you will need the right box tuned higher to hit a 145+
My youtube channel, please subscribe
http://www.youtube.com/ballinblaza
Should do a 45-46
He didn't say his stuff is walled... Do what you feel player it's all good learn as you go. Just order you a dd-1 lol
Should do a 45-46
Just because you can do it, doesn't mean his will. I have no doubt that you can use this same equipment and get that score, but that's cause your you.
I had a DD3515 on a DC2k in a 3.5 cube box tuned to 36 hz designed by Fecupe and was only hitting 142. Doubt doubling the cone area would have gotten me a whole 3 db.
:rofl:
:wub: N8.
Should do a 45-46
your on crack..
...no you are, ive personally seen a pair of 8's do a 149 on less then or no more then 2200 clamped...
ive also personally hit 148.7 tuned to 30hz....
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
Should do a 45-46
lol i agree with you.. my 4 15 inch L7s tuned at 32hz on 3300 RMS hit a 146 at a car show i went to a few months ago.. its hard getting high DBs when you tune low..
