Mechman dual alt adjustable volt harness caught fire.
it actually melted the plug solid and took some serious work to get out. I was shitting bricks
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
mine works perfect..
can you explain your wiring or a pic so i could take a look??
mine is a 1/0 lead to each positive stud on my dual kit and then the big three grounds. nothing hokey rest voltage is 13.4. if im not driving its on the intellicharger. my truck has 0 miles on it from the install. I moved it across the yard for the hurricane and thats what happened when i stopped
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
My truck last week tried to do the same but with my vcm. I have three alts currently and one had a bad regulator, replaced it and hooked everything back up and start truck and my voltage jumps to 18.8 so I shut it down remove the vcm and charges at 14.7 so I said to hell with the vcm and removed it.
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
and the avbm piece is plufg and play plus the lead that connects to the #1 alt charge post right?
ive had that problem with the VCM also..
but not with the avbm
correct ray. I followed the instructions to the letter. id bet total engine running time was less than ten minutes. however long it took me to dial it in to 15.2 cold(im still not done iwth my truck dont need it any higher) and play with it for a few minutes and hten shut it off and move it across the yard a few weeks later.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
d(-__-)b
Yeah its all plug and play, There is a plug that goes to the factory plug...then two plugs that go into each alt. On the first plug there is a short red wire that goes to the output stud on the alt.
My factory plug is a 4pin plug with only two pins, the center two. The Mechman harness is a 4pin also...but it has three pins in the part that plugs into my stock harness. The other two plugs in the harness are both 4pin plugs with 4 pins... I have no idea what any of the wires do.
d(-__-)b
So have any of you even contacted Mechman about this yet? It sure does make me feel a whole lot better knowing I am not the only one. Any ideas what causes this issue?
d(-__-)b
  • Who's Online   1 Member, 0 Anonymous, 1534 Guests (See full list)
