I was inspired by Rob Wolcott's 8 inch aero and wanted one just like it. Then I ended up finding out that I know the guy that made his. So I definitly got one.
Check out that crucial Icehouse tallboy as comparison.
WHAT COLOR SHOULD I PAINT IT?
1999 Monte Carlo
Sony CDX-GT34w
2 Alpine Type R 12"s in 4 cubes tuned to 35hz
American Bass VFL 80.1 amp @ 1 ohm (probably doing between 1000 and 1300rms)
Stock alt, Stock batt, Big 3 Upgrade
Boston s55- 5 1/4s (doors)
Boston s95- 6x9s (rear deck)
A florecent pink would be pretty :)
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
sir, you are brilliant. Kam311 FTW.
1999 Monte Carlo
Sony CDX-GT34w
That is a bad ass port by the way man!!! How did he flare the PVC out like that? Did he just heat it up and do it very slowly and carefully?
so far...
na i think he said he has some kinda machine for it
1999 Monte Carlo
Sony CDX-GT34w
Well there goes my idea Haha
so far...
... yes thats it
R.I.P!
(Nov-29-2009)
92 explorer
current build
well he said he used a flaring machine.
1999 Monte Carlo
Sony CDX-GT34w
... yes thats it
Hey man I've seen some pretty talented people haha, it could be done
so far...
that may be how he makes his but i know alot of people make a fiberglass/bondo base and use heat to form the pvc around
or they use a metal bowl and heat to flare it
R.I.P!
(Nov-29-2009)
92 explorer
current build
