FUSION JONAH LOMU FJL-1211D D Class Amp
awall1022
My uncle is willin to sell me his Fusion Jonah Lomu FJL-1211D D Class Amp for 100$. i plan on pushin my FI SSD 15'' with it. i know fusion is a shitty brand but ive done alotta research on this amp and i have never heard one thing bad about it noone as ever posted anything about frying it the only thing people say is it gets hot lookin for a few opinions if anyone knows anything about these amps. Here are the specs on it
14.4 Volt Power Output Specs
800 WRMS x 1 into 4 Ohms
1250 WRMS x 1 into 2 Ohms
1700 WRMS x 1 into 1 Ohm
Gold plated audio input and output connections
FUTRANZ Efficient Heat Sink design technology
F.I.S.T Fusion Intercooled semi conductor technology
Variable sub sonic filter 10 Hz - 35 Hz
Signal to Noise ration > 90 db
RCA output for multi amp installations
Direct in 4 gauge gold plated power connector
Military spec componentary as standard issue
Damping factor > 200
Total Harmonic Distortion 0.05%
Variable Low Pass Crossover @ 18 db per octave
Variable Phase Shift 0 - 180 Degrees
Variable 'Q'
Variable Input Adjustment 200mV - 7V
RCA Input and Pass Thru
Chrome Anti-tamper Cover
5-Way Protection : Thermal, Overload, DC-Offset, Short Circuit, and Reverse Polarity
Dimensions (mm)(W) 275 x (L) 365 x (H) 65
lifted trucks gorgeous sluts a pretty face and slammin bass
My current Set up
Car less :(
I Do Ported Box designs/cutsheets with 3d google sketchup model just PM
i would really want an in-depth guide
Just flip the fucking thing over
alright update. got the amp today and here are some pics
Gold plated Connectors
For those of you that love amp guts
My current Set up
Car less :(
I'd run it at 2 ohms if possible for reliability, or just turn the gain down a bit if you have to run near 1 ohm. Looks like it would 1500w ok, but I wouldnt push it.
Decent for $100 though :)
Hammerdown... 1%
planned on runnin it at 2 ohms daily for the 1250w so ill probally be ordering my FI in a couple weeks. just standard no options dual 1 and later on when i have the money to upgrade amps i plan to get a second SSD
My current Set up
Car less :(
I'll take it if you wanna sell it. It would match my other one, lol.
id buy your other one if you wanna sell it :P
My current Set up
Car less :(
Does he have the case that it came in lol, i bought two brand new. Sold one now i wish i didn't.
yeah he doese he is bringin it over today and the top chrome panel
My current Set up
Car less :(
  • Who's Online   0 Members, 0 Anonymous, 1688 Guests (See full list)
