Ok so my friend is running two skar audio VVX-12's on a planet audio 1250D at .5 ohm, on completely stock electrical, i've heard of people giving the subs a clean 1000rms a piece without any issues, I noticed that with these subs i'm guessing they are getting about 800rms a piece and they get very hot and a little smelly after about 10min of playtime. Can an amp at .5 ohm send a clipped signal if its being ran lower than its rated ohm load and if it's not getting proper power to run at .5 ohm? Like if he runs an SAZ3500D at 2 ohms with good electrical and we clamp it at 1600rms for both subs will we get the same results or will they run cooler and not get smelly?
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
he's more than likely clipping the subs if they're getting hot after just 10 minutes of play. why did he get dual 2 coils instead of dual 4?
he couldn't pass up the offer, 200 for both new.
understandable. what voltage is he dropping to when playing music?
12.1 from idle at 13.5, he's also running about 700rms worth of mids and highs.
Turn the gains down. Squares are bad for subs.
it's at half gain also :shrug:
You are not getting 1600 out of that planet. Lol
How bout maybe 900 Maybe
planets are clipville in the first place. what amps giving 700 to highs? im giving almost 600 in highs and my shit is rediculous.
