Dan2427 Posted July 7, 2011 Report Posted July 7, 2011 Well I'm looking at redoing my mids/high set up. I already have speaker wire ran left in from previous owner. So my question is, can I use a jumper wire at the crossover to power the tweet or should I run more wire to each crossover? I'm looking at running a T5002 power amp and I need to run 3 sets of components. Will the crossovers still let me run the single 4 ohm wired together for an impedance of 1.34? Sorry if this doesnt make sense I will double check when I wake up. Thanks a ton. Dan. Quote 2003 GMC Yukon Denali Alpine CDA 117 Redoing Mids/Highs 4 Runs of 1/0 Knukonceptz 2+, 2- 4 Deka 9A31's in back (Stock underhood) 250 amp Alt. AQ20K 2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
MrSkippyJ Posted July 7, 2011 Report Posted July 7, 2011 Well I'm looking at redoing my mids/high set up. I already have speaker wire ran left in from previous owner. So my question is, can I use a jumper wire at the crossover to power the tweet or should I run more wire to each crossover? I'm looking at running a T5002 power amp and I need to run 3 sets of components. Will the crossovers still let me run the single 4 ohm wired together for an impedance of 1.34? Sorry if this doesnt make sense I will double check when I wake up. Thanks a ton. Dan. You don't have to use the tweeter input, It is an option. If you are only going to run a jumper to the tweeter input it wouldn't make any difference. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
bre2ts Posted July 7, 2011 Report Posted July 7, 2011 Quote Feedback 1 | Feedback 2 you win some, you lose some
MrSkippyJ Posted July 7, 2011 Report Posted July 7, 2011 ah sorry, you do need the tweeter input, not the woofer input. Still no need to use both inputs if they are going to be a single signal. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Dan2427 Posted July 7, 2011 Author Report Posted July 7, 2011 Awesome thanks guys! Looks like it will be plug and play then! Quote 2003 GMC Yukon Denali Alpine CDA 117 Redoing Mids/Highs 4 Runs of 1/0 Knukonceptz 2+, 2- 4 Deka 9A31's in back (Stock underhood) 250 amp Alt. AQ20K 2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
