I'm going to be building my box this weekend and I want to make sure it's 100% good. It's for two 12'' DC XLs powered by a DC 5k.
Here are the specs with design:
The amps won't be located there any more.
Click Links To View Build Logs
1994 - Mazda B3000 (Daily/Toy/Show)
2002 - Mazda Protege (Daily)
1995 - Hyundai Accent (R.I.P.)
1984 - Bronco II (Restoration Project)
Youtube Channel
You might need bracing but besides that the numbers look ok.
Big 3 with Yellow Top
The answer is no! The proper internal cube recommendation for your subs is 1.2 to 1.5 per driver. Any bigger and you'll loose control especially with power. These are what both Rusty and Thor recommend. That said I began with a box that was 3.8 cubes and have reduced it down to near 3 prior to building another starting at 3 cubes.
Edited by Soapbox
TEAM FLEX ISSUES, TEAM DC AUDIO
2010 California State Finals Champion MECA AS2
2011 California State Champion Meca S2
2011 California State Record holder Meca S2
2012 Meca Mod 4 class 152.5 and rising
Rise on the 3.8 box was 4x.
You're going to want to brace the baffle at the very least. That's a big panel.
I'm not saying this is the case, but I do want to ask more knowledgeable people a more specific question using your design.
I know placing subwoofers next to a port can cause loading and cooling issues. What I don't know is what criteria would need to be met for this to be a problem. Would this box encounter those kinds of issues since The right-most sub is near the port? OR would it only be an issue if the port opening is on the same axis as the subwoofers themselves?
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
What would be a typical displacement for bracing? the inside of the box is 12.75'' tall.
Youtube Channel
hopefully your subs dont have the loading problem like mine do wit hthe box design you gave me, doesnt look a whole lot different then mine lol
Driving my 2008 Dodge Ram 2500 MEGA cab with the 5.7 hemi.
Audio: Two 10" Alpine Type R's ( 1000rms models )
Hifonics BRZ 2400.1D @ .5 ohm
Two Kinetic 1400 batteries ( soon to have XS power under hood )
Tsunami 1/0 Awg wire throughout truck.
Stock Infinity 7 speaker system ( Junk ) soon to be replaced, probably all Alpine.
Exterior: 17"Dick cepek rims with 33" Toyo MT tires
Bushwacker fender flares
Magnaflow true duel exhaust
LED tail lights with Projector headlights
Plasti-dip fun coming soon!
  • Who's Online   0 Members, 0 Anonymous, 934 Guests (See full list)
