irpirates 4runner rebuild - 4 15's 6th order. i haz TL numbaahhss
i can't wait either lol. helpin a friend with a 2 18s blowthrough so i got my plugs cut today lol. gonna end up doing an outer layer sitting on the wall. rather have it stronger than lookin nice but weak.
another asian? who's a basshead? no way. coulda swore i was the only one xD
hiiiiiiii
2002 4runner - buncha speakers n amps n shit (gone)
1994 astro - more stuffz
update: pretty sure all the pic links in the logs are broken lol.
ma slop garb build log
16 12's 4th order
4runner rebuild in progress
clickkk meeeee!!!! 4 18's 6th order
UBL - clicky
http://www.youtube.com/yyj11589
lots of hater kids here. Pay no attention, they just want 89,000 watt subs for 3.50
If you would have put a dc dustcap on it and called it lv your mom, they would all be in love
so this system is for daily groundpounding. very few burps will be done.
had bo tell me on another forum
"16 volts may get you more power for a burp, but you won't get more sustainable power. Ask Jeff Rowland. He has a ton of 16 volt batts and he drops to around 10 or 11 volts 3 seconds after he starts the music. He wants to switch to 12 volts so he can have more sustainable power."
so....
4 3500s @ 1ohm.
200.4 @ 1.3 per channel
125.2 @ 4 ohms bridged
if i do 12 volt will be 270 xp and a EA 300 both charging at 14.8-14.9 hot.
total of 7-9 xs 3100s (will need to check if i can fit 3100s behind front seats)
or
16 volt. 270 xp on 12 volt system with 2 3100s. EA 300 on 16 volt system 7 xp1000s.
opinions please? thanks!
hiiiiiiii
16 12's 4th order
UBL - clicky
okay, well i just remeasured the space i have. i think i'm going to stick with 12 volt...can't fit the 16 volt behind front seats. really doubt 5-6 is gonna be enough lol.
lookin like it's gonna be a total of 7-8 3100s and 2 5100s. hopefully that'll be enough >.<
hiiiiiiii
16 12's 4th order
UBL - clicky
i lied. still doing 16 volt. lol. ill hafta make a few small changes to the front of the wall and bat space in the back but i can fit 9 xp1000s. with 4 3500s @ 1 ohm a piece i should be fine.
hiiiiiiii
16 12's 4th order
UBL - clicky
you'll get more power on music running 16v no matter what. if jeff rowland was running 12v he'd be dropping to 7v. those 3500's LOVE 16v as well.
you'll be at a much better bl to cone area ratio with the 15's. i doubt you'd have the same problem with 6 15's as the motors has much more control over the cones in that scenario, although that might lower the effective volume for each driver as you'd have more cone area.
none the less, in for results of the 15's
thanks for the reassurance haha. actually talked to dj last night about it as well. as much as i would love to do 6 15s money says no. and no more cramming stuff into small spaces for me. be tough getting them on the baffles properly (not enough surface area where the subs would be loading against a flat back wall).
it'll be a while before i can get everything up and playing again but thanks for stickin through with me everyone.
hiiiiiiii
16 12's 4th order
UBL - clicky
If you where gonna go 7 xp1000 vs 7 d3100, even tho you have 4 more volts of potential to work with on 16 you also have a few hundred more pounds worth of lead for 12 volts. Based on your options I would stick with 12 volt. Pounds of lead per watts ratio you want as high as possible.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Let me know when you're doing the recones and ill be on my way to chillax mudda fucka haha
2004 Bagged Trailblazer
(4)18" Sundown Nsv3s
(4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4
(2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
1 alt. 9xp 1000s for the 4 3500s @ 1 ohm
or
2 alts. 10 3100s for 3500s @ 1 ohm. 200.4 @ 1.3 per channel. 125 @ 4 per channel. and car.
just going off the 1500-3000(competition/daily) rms per battery suggestion of XS it should be close, especially with the amps at 1 ohm. i've always wanted to do 16 volt just so even if i did drop voltage would still be fairly high.
hiiiiiiii
16 12's 4th order
UBL - clicky
