scrap that, would this work http://cgi.ebay.ie/DURITE-12-VOLT-BENCH-POWER-SUPPLY-UNIT-/310286084910?pt=UK_Home_Garden_PowerTools_SM&hash=item483e7deb2e the same as the one you posted Kirill007???????????
It only outputs 10 amps.
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
I said 50 amps is not enough, so 10 amps will be worse.
But that 50 amp power supply should work. It's not like you are gonna pull all the current that the amps are rated for.
true, so 50 amp would be fine then, so ether 50 amp or 100 amp would be fine then so you want me to get this http://ie.farnell.com/jsp/search/productdetail.jsp?sku=1821485&CMP=LEC-XPPowerSC&ATT=1821485
Edited by Dubpower
That one is better but you could buy 2 of the 50 amp ones for less then that :)
And you just spread the load equally so both power supplies have to deliver about the same power.
so what you are saying is that, I should get this \/ \/ run the positve wires to it and then the 2 wires of it then, take have the current throw the 2 wire coming from the block
then run the 2 wires to this \/ \/ \/ then and I am sorted
