Permanent fix for bass breakage?
I am wanting to fix the hatch hinges on my Mountaineer but I want to find a way to fix it so the problem does not return. Any idea's?
Part I am interested in finding a permanent repair for.
Problem solved.
But really, in all seriousness, id get a reinforced metal hinge or something...otherwise, im not sure how you would fix it as those simply wont take the abuse. That being said, I could see that bitch tearing your roof too...hrmmm.
id say silicone, seeing as it will streach a bit, but that wont solve your problem :/ my jeep has steel hinges try something liek that
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
Could you tell me what the spacing is on your jeep hinges?
From where it mount's on top to the mount threw the glass (bolt to bolt that is)
Have you replaced it before this? My woman's hinge snapped off in the middle of winter and the replacement hinge was metal, they realized plastic was a bad idea. She has a ford escape though. Ran us $200 and an hour at the dealership.
Ill have to look into that. Would be nice if I could just buy the part and replace it myself not that hard to do.
  • Who's Online   0 Members, 0 Anonymous, 2483 Guests (See full list)
