18abVFL Posted July 9, 2011 Report Share Posted July 9, 2011 Im buying a 2001 Toyota Celica GT in a month, and im puttin a nice big system in it. Probably gonna be a Audioque HDC3 18" on around 2000rms. Thinkin of either a Crescendo BC2000, AQ2200d, or an American Bass HD3500. What should my elecrical system be looking like? Will i be fine with stock alternator, stock batt up front and kinetic in the back? Which Kinetic should i get? Quote 1999 Monte Carlo Sony CDX-GT34w 2 Alpine Type R 12"s in 4 cubes tuned to 35hz American Bass VFL 80.1 amp @ 1 ohm (probably doing between 1000 and 1300rms) Stock alt, Stock batt, Big 3 Upgrade Boston s55- 5 1/4s (doors) Boston s95- 6x9s (rear deck) Link to comment Share on other sites More sharing options...
Supercharged DCs Posted July 9, 2011 Report Share Posted July 9, 2011 What size alternator does it have? If it's 110+ you should be fine with the Big 3 and the largest XS battery you can fit under the hood (D3400 and up). Quote Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012. Link to comment Share on other sites More sharing options...
18abVFL Posted July 9, 2011 Author Report Share Posted July 9, 2011 What size alternator does it have? If it's 110+ you should be fine with the Big 3 and the largest XS battery you can fit under the hood (D3400 and up). cant i just connect the stock batt up front to a xs or kinetic in the back? Quote 1999 Monte Carlo Sony CDX-GT34w 2 Alpine Type R 12"s in 4 cubes tuned to 35hz American Bass VFL 80.1 amp @ 1 ohm (probably doing between 1000 and 1300rms) Stock alt, Stock batt, Big 3 Upgrade Boston s55- 5 1/4s (doors) Boston s95- 6x9s (rear deck) Link to comment Share on other sites More sharing options...
sqsux Posted July 9, 2011 Report Share Posted July 9, 2011 What size alternator does it have? If it's 110+ you should be fine with the Big 3 and the largest XS battery you can fit under the hood (D3400 and up). cant i just connect the stock batt up front to a xs or kinetic in the back? yes, some people like replacing the stock battery before adding batts for a reason i don't know. I ran a 2200 on stock electrical + an HC600 for a long time, not sure how the voltage was. Quote Start out boxy, shape as you move along. Dc Audio Team Fur Link to comment Share on other sites More sharing options...
Supercharged DCs Posted July 9, 2011 Report Share Posted July 9, 2011 Yessir, but it's normally recommended to be running the same type of battery in the rear and upfront, such as AGM up front AGM in rear. Your stock battery will probably be Lead Acid. Quote Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012. Link to comment Share on other sites More sharing options...
homiewes Posted July 9, 2011 Report Share Posted July 9, 2011 What size alternator does it have? If it's 110+ you should be fine with the Big 3 and the largest XS battery you can fit under the hood (D3400 and up). cant i just connect the stock batt up front to a xs or kinetic in the back? yes you can.. but with 2k rms i still think you are going to have some bad voltage drop even with an extra battery.. Quote My youtube channel, please subscribehttp://www.youtube.com/ballinblaza Link to comment Share on other sites More sharing options...
18abVFL Posted July 9, 2011 Author Report Share Posted July 9, 2011 What size alternator does it have? If it's 110+ you should be fine with the Big 3 and the largest XS battery you can fit under the hood (D3400 and up). cant i just connect the stock batt up front to a xs or kinetic in the back? yes you can.. but with 2k rms i still think you are going to have some bad voltage drop even with an extra battery.. how bad? i mean its only 2k... I would think voltage would be alright as long as i add a batt Quote 1999 Monte Carlo Sony CDX-GT34w 2 Alpine Type R 12"s in 4 cubes tuned to 35hz American Bass VFL 80.1 amp @ 1 ohm (probably doing between 1000 and 1300rms) Stock alt, Stock batt, Big 3 Upgrade Boston s55- 5 1/4s (doors) Boston s95- 6x9s (rear deck) Link to comment Share on other sites More sharing options...
Supercharged DCs Posted July 9, 2011 Report Share Posted July 9, 2011 I've probably said this a million times by now, but with a stock 117A alternator, big 3 and a single XS D3400, I had virtually no voltage drop with my DC2k. Quote Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012. Link to comment Share on other sites More sharing options...
homiewes Posted July 9, 2011 Report Share Posted July 9, 2011 I've probably said this a million times by now, but with a stock 117A alternator, big 3 and a single XS D3400, I had virtually no voltage drop with my DC2k. ahh your prolly right, i havent ran that little of wattage in awhile, but now i think about it, awhile back i was running 1750 rms with a stock 140amp alt in my explorer and just a small hc800 kinetic and i didnt have any voltage drop.. Quote My youtube channel, please subscribehttp://www.youtube.com/ballinblaza Link to comment Share on other sites More sharing options...
18abVFL Posted July 9, 2011 Author Report Share Posted July 9, 2011 my alternator is only 80 amps....will this suffice? Quote 1999 Monte Carlo Sony CDX-GT34w 2 Alpine Type R 12"s in 4 cubes tuned to 35hz American Bass VFL 80.1 amp @ 1 ohm (probably doing between 1000 and 1300rms) Stock alt, Stock batt, Big 3 Upgrade Boston s55- 5 1/4s (doors) Boston s95- 6x9s (rear deck) Link to comment Share on other sites More sharing options...
