2011 Chevy Tahoe, 10k watts, 4 Fi BTL 15s, 4 DC Power alts!
Just a thought but another thing u might be able to do to brace the roof is add aluminum bars (or anything else) in between the roof braces and put some second skin over it
2008 TahoeHU-PioneerMids/Highs amp- sundown 200.4Mids/Highs- hertz xls, hertz ml 700, audison voce tweetsAmp-2 AQ 3500sSubs-FI SP418sAlt-singer 350Big 3 1/0
Build Log
UBL My YouTube channel
I was the first guy to use external rhino liner on the outside of my roof. I did it cause I was lazy and didnt want to pull my system it helped noise and flex alot but it became a issue in meca and my class so I had to take it off. I did get many compliments and there's a local shop by me were I got it done for a couple hundred. It looked factory
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
i cant imagine how shitty that was to remove.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Yes at 1st I was dreading it after I googled it it said you had to use some chemical that required a resperator and pretty much a hazmat suit lol I was like wow. Then I just took it back to the guy that sprayed it he said he would do it for 100 bucks I said kool. All he did was cut the length in 3 big strips and peeled it off. I didn't see him do it but it had to be hard. I just through some black primer up there and its still like that
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Ya know in all honesty, if you're gonna pull the angle brackets, why not go through the work to do what you pictured if that's what you like. Then cut strips of deadener and put between the bars to deaden everything between, then make it level with the bars, and lay one layer of deadener over the whole thing, followed by the headliner. I mean if you're gonna go through the work of stripping it out, you might as well do it right and not go back in a couple different times to correct what you could do the first time. Make sense? Just my opinion, and suggestion. Take it how you want to.
I don't think I realized you were not too far away. Let me know when you're tuned in and running and I'd love to come check it out sometime!
Use the rhino liner on the braces, than cover it with deadener?
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
i 4got to ask how thick is that metal u use for the amp rack?
and only thing that bugs me is the wire showing....but that just me ocd :lol:
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
woah just read this thread dude love it i love Fi stuff :P run a BL myself haha
also just to say i love the amp rack you made so simple yet effective :D
cheers
paul
HU: Pioneer AVH-3300BT Mids: 4x Ground Zero GZCM 8-4PP-CL Tweeters: 2x Ground Zero GZCT1800 Compression tweeters, 2x Ground Zero GZCT0500 Tweeters Subs: Sundown SA12 x4,Monoblocks: Sundown 1500D V3 x2, 4 Channel: Sundown SAX125.4, Batts: Banner Running Bull 92Ah x3 Alt: 210amp De-regged
New additions to come: 4x Corsair AF120 120mm Cooling fans, More Leds, 18mm MDF roof
I was talking about the braces, like what you took down from the roof already, and then you posted the picture about the flat iron and why didn't you think of doing it that way. I was just talking about that. Then filing between those with the deadener, and then over the top of it before you put the headliner in.
Since I can't multi quote,
I love wiring, especially if you're doing it nice and neat and not making a rat's nest! Your's looks clean already. Definitly a lot of wiring to do though, and I'd love to help but even danville is a bit away to jump over and lend a hand. I'll just watch from here!
I've heard tig welding is the easiest to learn and do. I'm gonna see about that too before I start restoring my truck. I wanna weld and never learned how.
I'm gonna have to get with you when I get close to done with mine. I would buy something line that o scope but I don't have a clue how to set gains by that. I usually go by east and say ya that sounds good or no it doesn't. Also what cm. are you using? I need a new one and don't know what are good ones to get. Write looks great, nice and clean! Keep it up buddy!
