2 15s, 3 12s, 4 10s, 6 8s for s trunk car
armykyle1
here are the 8s i have
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=264-833
and yeah it does look sexy
is that just two sealed boxes or some kind of 4th order?
I like the neo motor, save a little weight and space. How do those sound?
so I did some real measurements ( i guessed before sorry) I have 10.9 cubes of useable space w/o going in the the spare tire well and behind the strut mounts. so we'll just say 10 cubes.
the actual opening into the cabin is 38x17 but I can trim some of the sheet metal out to 38x19
i was doing some displacement math with the titanium 15 vs the 3 D6 12s and the rli-10/8s and the 15 has more actual displacement than any of the other setup, due to the high xmax. 1.75" and the SD is 800
so would a single 15 still be best or?
maybe 2?
will a 10 cube box fit through the openings to get in the trunk? or are you going to build it inside the trunk?
I also wouldnt cut anything out, you might not compete now, but if/once you start youll be at a disadvantage.
and since you are dead set on filling the trunk completely, you have room on the face to do forward firing 15s, but unless you have around 8 cubes before displacement i wouldnt do it.
So if you can get a depth of around 27~28" then the 2 15s are do-able,
I would have to build in the trunk. I've never done this though. I'm guessing I'd have to use L brackets to secure it internally? lots of resin?
Because of lessened rigidity?
No, because of not being able to compete in the trunk class.
even if the seats still fold up?
I'll get a better pic later but where the top starts to curve I can go strait up and level with deck w/o hitting the cross bracing
am i correct by multiplying sd by xmax*2 to get total displacement of the cone?
Even if the seats fold up. When you cut metal you get thrown into crazy classes :)
btw, I have heard those 8s in that car. it won't disappoint!
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
how would 6 of those compare to a titanium 15? cant put as much power on those 8 though.
I haven't cut any metal but I took the rear deck out, will they put me in a diff class for that?
Not sure about the rear deck, probably differs from organization to organization.
I have no idea how a titanium 15 sounds so I have no idea how it would compare.
F150:
Stock :(
Processor: DSR1
thats understandable.
the 15 has 1.75" xmax it can move lol
thank you for the replies
those are in two ported boxes
the sound is fantastic. clean and warm. i think they are the best subs ive had so far. as far as power goes im giving them 2k and they only got warm once. that was after 45 seconds full tilt on music which was after a 3 hour drive of beating on them too lol
these things are stout
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
two obsidian 15s will fit in 6 cubes, 3 obsidian 12s will also fit in 6 cubes
too much $$$$$$
I'll deff look in to them. gonna put me a little over budget though lol
I'd Get 1 18
Fi BTL 18 6 cubes 32hz
2500-3000 watts
get like a rockford, kicker, crescendo or DC..etc
you will be slamming
(2) RE SXX 15
(1) Rockford T1500bd-cp (Bass)
(1) Kinetik 1800 (Rear)
(1) Kinetik 600 (Rear)
(2) MB Quart 1"
(2) MB Quart 5.25" components
(2) Kicker KS 6x9
Pioneer Head unit
8.1 ft^3 @ 35hz
Stinger Volt Meter
Interstate Battery MTII-78 (Front)
Stock 130 amp Alternator
1/0 Gauge
(1) Pioneer GMF-4300 4 channel amp (Mids and Highs)
Saab 93 in Pristine Condition
~Awaiting~
Big3
Audio Technix Sound-deader
(2)JL TRX 3.5"
(4) Pioneer 6.5's
