Port Triangle? Yes or No
22 members have voted
  1. 1. Should I use a triangle where the port splits?
45´s suck ass IMO, after i tested them i said i´ll never use them again on a daily box. About my idea, well, i totally understand your point about your application been way different than mine, but if you guys have gotten way better results with the triangle instead of my idea, why bother? Orion, you already got GREAT inputs, this is a one side decision for sure now, no reason for me to test this so i can help you out making a decision, but now you got me very curious lol, i wanna try that triangle in a box with the squared tip, let me see if i can find a box to test that thing :)
I would only use them on the pressure points of the box , if you use 45´s on the back corners i think you would mess a little bit with the airflow since the opening isn´t that big, i would use them here only if it´s a sub back/port back box, if it´s a sub up/port back box then it´s totally different
Edited by fecupe2001
i would also keep them at the same corner as fecupe said it will further more secure that L port and if its subs up port back i would put it on the bottom of the box horizontal facing the back of the box
You are right my friend, but i´m pretty sure it´s subs back/port back since he has double baffle without the top plate of the box attached yet :)
Dont get 45´s , rounding over with PVC worked way better for me, it´s also easier if you don´t have a table saw or something like that , just cut a 4" pvc tube into 4 pieces, use 2 of them for those corners and sell the other two lol
  • Who's Online   0 Members, 0 Anonymous, 941 Guests (See full list)
