how to tell a blown sub
long story short,blew the preamp on my amp a few weeks ago..well picked amp up today,took home and hooked system back up.well still no sound out of the subs.idk if its something to do with the wiring or the subs.but i've looked each sub over bout 50-100 times,and they both look fine.but being im still a rookie at this.idk if their ok or blown.their the older model SE's btw
JUGGERNAUT DA ASSO
check the resistance on your speaker leads from your box. if you get a reading then they subs are probably okay. if not i would pull them and check resistance at the coil in case they got disconnected for some reason
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
hook up a vom meter to the sub terminals on at a time (pos and neg) make sure the meter is set to detect Ohms. if you get no reading on one of the coils it is blown.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
ohm meter, not vom. Digital $20 jobbers from crappy tire/target/whatever work great
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 754 Guests (See full list)
