Mecca421 Posted July 19, 2011 Report Posted July 19, 2011 I have built my first budget bass setup in my 96 grand marquis. I'm using a kenwood 9105d mono amp rated at 900 watts @2 ohms which has 3x30 amp fuses. Two 12 inch kenwood 3012's in a ported box tuned to 38Hz. Originally I bought a 100 amp circuit breaker which I installed 1ft from the battery, instantly the circuit tripped when I turned the bass up. It was a cheap brand breaker so I just removed it. My question is, what size fuse should I be using? I have an AGU fuse holder with a 60amp fuse installed now, but I haven't turned my stereo up very loud worrying about it blowing and not having a spare fuse on hand. I ordered some hard to find 100amp AGU fuses but I hear that's not safe due to the fuse holder melting. I've heard people say to just add up the total amperage of the fuses on the amp, but I'm not so sure this is what to do.....I couldn't find this topic so I'm sorry if I missed it somewhere on the forum. You gotta crawl before you walk
Dan2427 Posted July 19, 2011 Report Posted July 19, 2011 What wire size? I believe your supposed to fuse the wire 2003 GMC Yukon Denali Alpine CDA 117 Redoing Mids/Highs 4 Runs of 1/0 Knukonceptz 2+, 2- 4 Deka 9A31's in back (Stock underhood) 250 amp Alt. AQ20K 2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
6berry Posted July 19, 2011 Report Posted July 19, 2011 yeah youre supposed to fuse for the wire. you should buy an ANL fuse holder and you can get fuses up to like 350 amps or more(not like you need that much but if you upgrade your wire later on) 1999 Audi A4 1.8T::: 4 - DC Level 3 10's in a 4th order Rockford P6002 on Subs for now (3-3.5k coming eventually) MB Quart ONX4.60 for Mids and Highs Boston S50 Components in Front Boston S65 Coaxials in Rear 40 Sq Ft of Second Skin Damplifier Build Thread UBL 1948 Plymouth
Guest Posted July 19, 2011 Report Posted July 19, 2011 you can switch to an ANL fuse holder, fuses come in wide ranges for ANL. heres a very affordable fuse holder you can use. http://www.parts-express.com/pe/showdetl.cfm?Partnumber=263-630
Mecca421 Posted July 19, 2011 Author Report Posted July 19, 2011 What wire size? I believe your supposed to fuse the wire Sorry its 4 gauge wire, I know about anl fuses but I already have the Agu for now, still wondering what size should I use, will my 60amp fuse work for my amp? The power wire is fused 1 foot from the battery.. You gotta crawl before you walk
