Are u using ring terminals with nut and bolt or ate you going to drill and tap the bar to use set screws?
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
1" wide copper with a 1/4" thickness will do
Not a bad price at all...comparible to the 1"x1" aluminum. You think copper that thin will conduct better than a thicker aluminum?
It does for me. I have two 6" long pieces, with the dimensions i suggested, on each terminal of my D5100 and they look/work great.
SMD Super Seller/Buyer
Audison----Hertz----Rainbow
The batteries I am using have bolts as battery posts like the standard stinger, xs, kinetik, etc. audio battery. So all I would be doing is measuring the distance between the bolts, drilling the bar, and setting it down over the battery and using a nut to secure the bar to the batteries. Then on the end I will run a bolt through, and use ring terminals on the wire going to amp.
  • Who's Online   0 Members, 0 Anonymous, 990 Guests (See full list)
