kryptonite Posted July 23, 2011 Report Posted July 23, 2011 Are u using ring terminals with nut and bolt or ate you going to drill and tap the bar to use set screws? Quote DC SOUND LAB NUT HUGGERCurrently Own 4 - 18" lvl 6s (m3) w/full Carbon Fiber option 2 - DC 5k lvl 4 motor lvl 2 motor On 8/2/2013 at 8:13 PM, n8ball2013 said: this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
Bakerman Posted July 23, 2011 Author Report Posted July 23, 2011 1" wide copper with a 1/4" thickness will do Not a bad price at all...comparible to the 1"x1" aluminum. You think copper that thin will conduct better than a thicker aluminum? Quote
memphisBred Posted July 23, 2011 Report Posted July 23, 2011 It does for me. I have two 6" long pieces, with the dimensions i suggested, on each terminal of my D5100 and they look/work great. Quote SMD Super Seller/Buyer Audison----Hertz----Rainbow
nismo114 Posted July 23, 2011 Report Posted July 23, 2011 ask cj18, he does it all the time. Quote get pyle on the inside of your butt cheeks...so every day you can take a pyle of shit
Bakerman Posted July 23, 2011 Author Report Posted July 23, 2011 Are u using ring terminals with nut and bolt or ate you going to drill and tap the bar to use set screws? The batteries I am using have bolts as battery posts like the standard stinger, xs, kinetik, etc. audio battery. So all I would be doing is measuring the distance between the bolts, drilling the bar, and setting it down over the battery and using a nut to secure the bar to the batteries. Then on the end I will run a bolt through, and use ring terminals on the wire going to amp. Quote
