so i have 2 kicker cvx 10s and im trying to decide on which ported box. according to kicker specs for best sq i need 1.75ft3 per sub but the box im looking at has 2ft3 per sub. how will it affect the tuning frequency? or is it too much volume? or should i say f it and go sealed? help please :)
edit: if it helps, i have a ss rubicon 1600
Edited by pd9665
Most people on here are going to tell you to build a custom box (which would be optimal). But what you're looking at will be fine. Just don't overpower the subs
Edit: Those subs also like bigger boxes than kicker recommends. Or at least the L7's do, so I figure the CVX's are probably the same.
Edited by DRauck
2011 Honda CR-Z Mugen
12" Kicker SoloX Subwoofer
Rockford Fosgate t20001bd
Pioneer AVIC-X930BT Head Unit
Build Log
I actually ran a CVX 10" in 2.25ish ft^3 at 38hz after playing around with it in BBP6 for a while. It performed REALLY well with about 600 watts RMS. Got loud, low F3, and seemed to love the larger box.
You should be fine, just don't go crazy with power.
-Zach-
2010 Toyota Tundra
Full Hybrid Audio SQ
7" BDS on 37's
2000 Ford Expedition
160+ dB Green Turd -SOLD- :(
thanks for the help and responses. i plan on running them at 2 ohms and 1100W rms
Per sub or between the pair? If that is per sub you may want to go with a slightly smaller box.
-Zach-
2010 Toyota Tundra
7" BDS on 37's
You should be fine then.
-Zach-
2010 Toyota Tundra
7" BDS on 37's
L7's and CVX's do like larger boxes. 3-4ft^3 at ~35hz for the pair should work well in most cases, so long as you're not trying to run more than rated power to it.
Edited by RAM_Designs
Ryan Miskin - owner of RAM Designs
I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script>
2200+ designs since March 2011...
  • Who's Online   0 Members, 0 Anonymous, 1901 Guests (See full list)
