cardy Posted July 27, 2011 Report Posted July 27, 2011 i have finally gutted and dynamatted the whole car out front to back i invision a nice surround sound sq system i can put speakers in the consol kick panels doors and back deck im listening for recommendations in the $2500 range last but not least i know two 12s in the trunk is a go but what about 2 15s will they be able to get the proper air space
6berry Posted July 27, 2011 Report Posted July 27, 2011 check out this build http://www.stevemeadedesigns.com/board/topic/103470-94beretta-and-fi-18-build-716-doors-started/page__view__findpost__p__1554754__hl__94retta__fromsearch__1 if you talk to him he'll probably have plenty of knowledge about your car 1999 Audi A4 1.8T::: 4 - DC Level 3 10's in a 4th order Rockford P6002 on Subs for now (3-3.5k coming eventually) MB Quart ONX4.60 for Mids and Highs Boston S50 Components in Front Boston S65 Coaxials in Rear 40 Sq Ft of Second Skin Damplifier Build Thread UBL 1948 Plymouth
94retta(219) Posted July 27, 2011 Report Posted July 27, 2011 Im not really sure what your asking? BUILD LOG
Audio-Concepts Posted July 27, 2011 Report Posted July 27, 2011 For an SQ based setup, you dont really want to have a "surround sound" setup! You would best be suited to either run a component setup or 3-way, plus a substage! You dont really want to have rear sound it takes away from imaging of your front stage and gives adverse soundwaves causing miscomception of where to sound is coming from. So my advice to you is run a front stage only (active or passive) & a sub stage! For your question about a 15" fitting, you can make any sub fit anywhere just depends on how bad you want it to fit! But if you are able to run an infinate baffle sub stage, a pair of 15's should not be a problem as long as you have the width. Pioneer AVH480 Zapco ST5XII amplifier Stevens Audio 6.5" components (passive) Onyx Subwoofer Sky High OFC wiring
94retta(219) Posted July 27, 2011 Report Posted July 27, 2011 What audio concepts said is spot on. As for ib15s yes there is enough room for that. Cuting it close but itll fit. Depending on your full setup up front you can put a pair of 6.5s or 8s in the back deck. Buut only have them pick up 50hz-400hz range and it will help your front stage out alot but wont effect stageing all that much because of the back window shape. I havent mettered my car ever but its easy to get loud. BUILD LOG
