Torquemaster69 Posted July 28, 2011 Report Share Posted July 28, 2011 (edited) Sorry if this isnt the correct area for this, but its the only place I could think of to post something like this because of the fact that I am still using an air system. ....Anyways, I have an air horn and about to get a pump and a 1.5 gallon tank for it. I was wondering what else I would need for this set-up as I am going to be putting an electronic switch in the cab. Anyone with knowledge of this would be greatly appreciated Edited July 28, 2011 by Torquemaster69 Quote I'm not shy, I'm just hiding how awesome I am so I don't intimidate you. 4 DVC 15" Lanzar Heritage Subwoofers 2 Soundstorm Labs 2600.2 Amplifiers 2 Yellow Top Optima Batteries 1 8 Farad Soundstream Capacitor 12 Inch Motorized Flipdown Screen Black Suede Roofline Link to comment Share on other sites More sharing options...
Torres Posted July 28, 2011 Report Share Posted July 28, 2011 first off...ROFL at your avatar lol. if your pump/tank doesn't come with tubing, you'll need some tubing. possibly some fittings as well. some kits come with these things, some don't. what is the PSI rating on your pump? you'll need an electric switch to cut it off when it reaches a certain PSI. and i assume the air horns have a solenoid built into them already. Quote Link to comment Share on other sites More sharing options...
teardrop Posted July 28, 2011 Report Share Posted July 28, 2011 what? kind of air horn are you running train big rig in know the big rig is 100 psi normal working pressure and train you can go 150-175 psi you will need a regulator a electric valve all of witch you can get at http://qualityairride.com/front_page Quote Link to comment Share on other sites More sharing options...
Torquemaster69 Posted July 28, 2011 Author Report Share Posted July 28, 2011 (edited) first off...ROFL at your avatar lol. if your pump/tank doesn't come with tubing, you'll need some tubing. possibly some fittings as well. some kits come with these things, some don't. what is the PSI rating on your pump? you'll need an electric switch to cut it off when it reaches a certain PSI. and i assume the air horns have a solenoid built into them already. HAHA....thanks...but the rating is 150PSI MAX (I don't need any bigger than that for this horn). This is the tank and pump I'm looking at http://www.amazon.com/1-5-Gallon-Viair-20003-Shipping/dp/B001ULAP1W/ref=sr_1_43?ie=UTF8&qid=1311882733&sr=8-43 The Horn is VERY simple....Its from a military vehicle and all it has it the horn part, and a hole to fit the airhose to right before the reducers...fairly simple. This is the horn http://www.tpub.com/content/trucks10ton/TM-9-2320-279-24P-2/css/TM-9-2320-279-24P-2_23.htm Edited July 28, 2011 by Torquemaster69 Quote I'm not shy, I'm just hiding how awesome I am so I don't intimidate you. 4 DVC 15" Lanzar Heritage Subwoofers 2 Soundstorm Labs 2600.2 Amplifiers 2 Yellow Top Optima Batteries 1 8 Farad Soundstream Capacitor 12 Inch Motorized Flipdown Screen Black Suede Roofline Link to comment Share on other sites More sharing options...
teardrop Posted July 28, 2011 Report Share Posted July 28, 2011 i had the same horn on my mini truck it was a bagged and shaved ford ranger i only shot 100 psi to mine and it was loud you will need a electronic vave a small one 1/4 in to open off a electronic switch just like a air ride system like this stuff is what i used http://qualityairride.com/air-management/valves/smc-14-valve http://qualityairride.com/catalog/fittings http://qualityairride.com/air-management/toggle-switches/carling-toggle-switch Quote Link to comment Share on other sites More sharing options...
Jd1102 Posted December 17, 2011 Report Share Posted December 17, 2011 first off...ROFL at your avatar lol. if your pump/tank doesn't come with tubing, you'll need some tubing. possibly some fittings as well. some kits come with these things, some don't. what is the PSI rating on your pump? you'll need an electric switch to cut it off when it reaches a certain PSI. and i assume the air horns have a solenoid built into them already. this^ times a million Quote Link to comment Share on other sites More sharing options...
got160s? Posted December 26, 2011 Report Share Posted December 26, 2011 What's a good cheap kind to get? I want one for my burban Quote Vehicle: 1999 Chevy Suburban AKA The Bammin' Beast Battery: 25 XS Power XP1000's Sub Amp: 3 DC 9k's Sub Stage: 18 DC Lvl 4 M2 12's in a Nasty 4th Order http://youtube.com/user/got160s Subscribe now! Prizes will be given away for every 1000 subscribers! Link to comment Share on other sites More sharing options...
POPLERO Posted December 26, 2011 Report Share Posted December 26, 2011 ^same question? And what's the lifespand on air horns? Quote 2008 TBSS Black Granite Alpine CDA-117 Clarion EQS746 AudioQue Supertweets @ dash Alpine DDT-s30 @ b pillars Alpine SPR-60c @ front doors Alpine SPR-60 @ rear doors Alpine PDX-f4 Second Skin DampPro KNUkonceptz Wiring DCpower 270amp alt Optima YT underhood *temp Two15DCxls Hifonics bxi2610 *temp saz4500 and 4 xp3000s coming soon. Link to comment Share on other sites More sharing options...
Jd1102 Posted January 4, 2012 Report Share Posted January 4, 2012 ^same question? And what's the lifespand on air horns? if you talkin about the horn i would assume it would last as long as you had it you just shoot air through it i don't think it has any movement i may be wrong but i don't see it really breaking Quote Link to comment Share on other sites More sharing options...
