well as the topic says, im thinking about doing some lifting and leveling to my van, the rear of the van sits about 1 inch above the rear tires and the front is about 3 inches above the tires and i think it looks like total hell, i love the way the e350s and 250s ride high
i was at the tire shop today geting new tires on the van, went from a 235/75/15 to a 255/70/15 this round and i like how the tire fills the wheel well nicely and i seen that my rearend is below the leaf springs , and instaly thought about geting redneck lift kit for the rear by useing them alum. blocks and extended u bolts to raise the rear 2-4 inches which would possibly level the front some, but i want more on the front and a little more on the rear so when i have the van loaded down like i normaly do it wont squat like a lil girl going pee in the woods.....
what would be the best way to improve my ride height while maintaing cheapness....i know its hard to do but i dont have much to dump into it since the tires stole the money i had for my new head unit, eq/line driver and 4 sets of 6.5's i was going to buy
is there a place where i can get custom built or prebuilt coils for the front of the van to raise the front via extended coils and use blocks/ and shackles in the rear... or how should i do it if im going to do it at all
the van is a 1980 ford ecnoline e100
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
i wouldnt run an aluminum block, i've seen them crack and get spit out.
another cheap alternative would be an add a leaf.
as for the front you might be able to find a coil spacer for it, most spacers will give you 2" of lift.
center console: lvl 4 12 1.75 cu ft tuned 37htz
alpine cda-9886
dc audio 120.4
infinity kappa 6.5" components
  • Who's Online   0 Members, 0 Anonymous, 1770 Guests (See full list)
