Second Battery?
Im running a Optima Red top under the hood and want to install a second batt in the rear. Im going to be getting a stinger sp1700 or a Kinetik hc2000 havnt decided yet but i wanted to know since im running the red top up front should i install an isolator or just wire the second batt parallel, since they arent the same battery will it be ok to just run them parallel.
2002 Ford Excursion
2 12" JL W7
1 JL 1000/1 ON SUBS
1 JL 450/4 ON HIGHS/MIDS
3 SETS OF 5X7 POLK AUDIO DB'S
200 AMP ALT BIG 3 IN 0 GUAGE WIRE
OPTIMA RED TOP UNDER THE HOOD
2 RUNS OF 0 GAUGE TO THE REAR
i would like some suggestions on the battery that you guys think i should run.
2002 Ford Excursion
2 12" JL W7
1 JL 1000/1 ON SUBS
depends on what you run as far as equipment.
Yeah sorry that I failed to mention that. Im running 2 12" jl audio w7 with a jl 1000/1 amp (soon to be 2) im running 3 pairs of 5x7 polk audio db off a jl 450/4 and i have a 200 amp alt its all in a 2002 Ford Excursion
2002 Ford Excursion
2 12" JL W7
1 JL 1000/1 ON SUBS
