Okay so I have two dual 4 ohm woofers wired like this
But when i hook my DMM up to any of the coils or the amp it says that its anywhere from 8-10 ohms?
I have the subs reverse mounted and on the deck (Pioneer AVH-P4300DVD) i have the sub polarity set to "reverse". Any ideas???
1990 Nissan 300zx Twin Turbo - Summer Ride(No system yet, lookin to get it up to 450-500 horse first!)2006 Chevy Malibu - Daily DriverDC Level 5 15", 2 APSM-1500's, 3.88 cu. ft. tuned to 32hz1992 Honda Prelude - SOLD2 18" TC 3hp Woofers on a Crescendo BC3500.1d, 12.7 cu. ft. tuned to 35hz7r.png
maybe .8-1.0 ohm????
How do the Japanese feel about bass?
You know that since 03/11/11
Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.
im pretty sure the op wont even notice if it gets even smaller.
Refs - Pstone11, porksoda, coleman
Do you have them connected to the amp while measuring?
If yes, disconnect them and measure.
If no, better:
Check your wiring
Check one coils at a time (disconnected)
Check you meter and settings
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
How does it sound? And try setting deck in phase see what sounds best. Most likely u have setting on dmm wrong
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
I have the setting on the DMM right and its not .8-1 ohm lol. & it doesnt hit very hard for two 18's so somethings weird
Maybe the dmm is on the wrong setting or turn off the deck and check it. Dont check it if theres power going through the wires those cheap multimeters cant handle it. Or one of your voice coils are damaged. GL
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
same thing happened yo me before, instead of 1 ohm it showed 10 ohm load.
Your subs are at 1 ohm, try using different DMM and check thru different parts of wire.
Okay thank you! Ill go pick up a different DMM soon. The one im using is really old but it still measures the speakers coils as being around 4 ohms each
Maybe its a damaged coil, or its your dmm
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
before you buy new one, try sticking DMM in different part of the wire.
