XS Power
Nathan,
What is the recommended and max alternator charging voltage for the D1400? I am planning on running 4-6 of them and using a Mike Singer 350a alt.
Thanks
Cody
For a "full" charge, the proper charging voltage is 16.8 volts. There are 7 cells, which are 2.4 volts each.
2.4A x 6 cells= 14.4 volts for a 12v batt
2.4A x 7 cells= 16.8 volts for a 14v batt
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
I charge mine at 16.8 with a vcm are these going in your ford
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Yes these are going in my F150 to power 2 DC 3.5k amps. I am looking to get the most out of the amps and since I am already running dual alts independent of each other I figured I might as well upgrade the batteries for the sub amp to 14v batteries.
I may be understanding you incorrectly and if I am just overlook my suggestions. If you are going to run two separate voltage systems. Then run 1 12V system and 1 16V system. No real need to run separate systems with the 14V and if you do then you might as well jump up to the 16v level.
You gonna be selling your current alts Cody?
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
How many 1600s would you recommend to power 2 dc 3.5ks that are rated for 5100w at 18v? Also doesn't it take a specially made alt to run at 18v or could I just use the vcm to adjust my voltage up?
  • Who's Online   0 Members, 0 Anonymous, 2325 Guests (See full list)
