thanks a ton for all your help looks like ill be buying new subs and getting rid of mine grr ill be out a couple hundred bucks but if the dang store i bought them from told me what i needed to know i wouldn't be in this perdicament!!!!!!
THANKS AGAIN!!! T1D412'S HERE I COME!!
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
You're gonna love those D4's on that amp. Will the place you bought them not just trade them out for the D4 coil version?
that would be possible but issue is im past the 90 grace period and to ship these subs back would be out of my pocket and at almost 40 lbs each that would run me about 100 bucs =\
BIG 3
RF T400.4
all stinger wires
Posted (edited)
Dont the cp amps make the same power at 2 ohms and 1 ohm?
In which case, while you would see some benefit of getting a 1 ohm load, I personally don't think it would be worth it.
Edited by BJD3
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
ok now 2 things first is
will it be worth all the trouble getting rid of these subs and buying new ones for only 77 rms watts more per sub??? prolly not in my book
second thing is this morning i had a electrical burnt smell coming off the sub in side of the amp. it has never made this smell its not horible and i have not changed anything since i have installed on day one
any ideas thanks
BIG 3
RF T400.4
all stinger wires
any ideas thanks
Not worth it unless you're upgrading from what you have to something higher quality such as DC/AA/FI/IA, etc.
Probably cooking coil...unless you mean the amp...then you could have burnt something up. Does everything still work?
Posted (edited)
any ideas thanks
everything works the same but like i said i never have smelt it before ill check ohms and stuff on my break in about an hour
and the smell is only coming from the amp not the subs
Edited by 01VWGREENMACHINE
BIG 3
RF T400.4
all stinger wires
Posted (edited)
ok i have check with a voltage meter i have 14.8 volts input power ground is good when i unplug the rcas from the amp and unhook the subs and touch the voltage meter to it and try to read the ohms it jumps all over the place for about 3 seconds then shuts the volt meter off. i also noticed when i have no music playing and no volume it crackles the subs when i adjust the bass nob.
any ideas im thinking bad amp (take in mind no rcas are hooked up while i was testing this)
also was thinking that if my amp has crapped out did it take out my subs so i hooked the voltage meter on ohms to each sub and im getting 3.7 ohms on each sub because there set at 4 ohm that should be good but i am not sure still learning alot this is my first big build! hehe thanks for all your help and support guys
BIG 3
RF T400.4
all stinger wires
You need to run each woofer at 1 ohm. Then run all the wires to the amp. The amp will then see two one ohm loads, which equals a two ohm load. So each sub will be receiving 884 watts RMS before rise. I hope this helps.
Wrong. The channels are paralleled internally. It would be like the amp seeing a single .5 ohm load.
-Zach-
2010 Toyota Tundra
Full Hybrid Audio SQ
7" BDS on 37's
2000 Ford Expedition
160+ dB Green Turd -SOLD- :(
  • Who's Online   0 Members, 0 Anonymous, 603 Guests (See full list)
