Ku-sama Posted October 26, 2007 Report Share Posted October 26, 2007 (edited) I have a ZX350.4 and I'm slightly worried about it overheating... it's in the rear seat well. I still have the seat installed so the plastic piece can cover it back up and make it look stock. as you might be able to see, it's a rubberish leather for the seat and it touches the top of the amp a bit. when all is said and done it looks like this: should I add a fan or something to circulate the air or am I okay? Edited October 26, 2007 by Ku-sama 225HP 1996 S-Dime JVC KD-G820 Crunch PZi 2250 powering Two Ascendant Audio Assassin 8s wired to 2 ohm at 225W RMS 2.26CF @ 36.4Hz 43.5 square inches of port with 45's Kicker ZX350.4 powering CDT CL-61A's with TW-24 Tweeters Contact me: AIM: Necromancer Ku YIM: Ku_Karukasa MSN: [email protected] Link to comment Share on other sites More sharing options...
Slinky Posted October 26, 2007 Report Share Posted October 26, 2007 it wouldnt hurt to add a fan. DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/ Link to comment Share on other sites More sharing options...
Ku-sama Posted October 26, 2007 Author Report Share Posted October 26, 2007 do they have thermal protection? 225HP 1996 S-Dime JVC KD-G820 Crunch PZi 2250 powering Two Ascendant Audio Assassin 8s wired to 2 ohm at 225W RMS 2.26CF @ 36.4Hz 43.5 square inches of port with 45's Kicker ZX350.4 powering CDT CL-61A's with TW-24 Tweeters Contact me: AIM: Necromancer Ku YIM: Ku_Karukasa MSN: [email protected] Link to comment Share on other sites More sharing options...
E a r t h Posted October 26, 2007 Report Share Posted October 26, 2007 Yes. And If you're running highs only like your sig has, you wont have any problems with overheating the amp Link to comment Share on other sites More sharing options...
Ku-sama Posted October 26, 2007 Author Report Share Posted October 26, 2007 sweet thanks! 225HP 1996 S-Dime JVC KD-G820 Crunch PZi 2250 powering Two Ascendant Audio Assassin 8s wired to 2 ohm at 225W RMS 2.26CF @ 36.4Hz 43.5 square inches of port with 45's Kicker ZX350.4 powering CDT CL-61A's with TW-24 Tweeters Contact me: AIM: Necromancer Ku YIM: Ku_Karukasa MSN: [email protected] Link to comment Share on other sites More sharing options...
Polecat Posted October 26, 2007 Report Share Posted October 26, 2007 it will shut off if it's going to go into thermal protection. IF it does that, then I'd advise putting it to where you can get some ventilation across the heatsinks. Behind every great man....is an underwear tag! Link to comment Share on other sites More sharing options...
Ku-sama Posted October 26, 2007 Author Report Share Posted October 26, 2007 it will shut off if it's going to go into thermal protection. IF it does that, then I'd advise putting it to where you can get some ventilation across the heatsinks. well it hasn't ever shut off on my yet where it's at.... in the winter it's going to be no problem because it's right next to the sheet metal on the outside 225HP 1996 S-Dime JVC KD-G820 Crunch PZi 2250 powering Two Ascendant Audio Assassin 8s wired to 2 ohm at 225W RMS 2.26CF @ 36.4Hz 43.5 square inches of port with 45's Kicker ZX350.4 powering CDT CL-61A's with TW-24 Tweeters Contact me: AIM: Necromancer Ku YIM: Ku_Karukasa MSN: [email protected] Link to comment Share on other sites More sharing options...
Polecat Posted October 26, 2007 Report Share Posted October 26, 2007 like the old saying then, "if it ain't broke, don't fix it..." Behind every great man....is an underwear tag! Link to comment Share on other sites More sharing options...
