I did it awhile back on my Cadence A7+HCs. They had the old type jack that uses phone wire.
98 Chevy Blazer 4 Door
Stock Everything
The New Setup
1 - Pioneer AVH-P5200DVD
1- Pioneer DEH-80PRS
2 - Blues Audio 5.25 Mids ( On the dash )
2 - Blues Audio BL8.0C Components ( In the front doors )
2 - Blues Audio BL8.0 Woofers ( In the rear doors )
1 - Linear Power 952 ( Dash )
1 - Linear Power 2202IQ Modified ( Components )
1 - Linear Power 3002 ( Rear Doors )
1 - SoundStream XBP-10 Processor
1 - SoundStream BX-20Z
2 - SoundStream DTR1.3400D
4 - RE Audio SX12D4
I don't see why not. If they are strappable, then problem solved. If not, then get a splitter for the phone cord, or just use the ones that go to the RCA's.
If it uses phone cord you can just use a splitter at the amps
Edited by Bigballa39213
Stock Everything
The New Setup
4 - RE Audio SX12D4
not all amps you can do that with. jesus.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
amp have a cinch out do the signal running the same at 2 amps wen i go to the cinch in on the other amp ???
JBL
While I understand English likely isn't your first language, I have no idea what you're trying to say here.
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
ok on the amplifier is a signal in and a signal out ,wen i using the amplifier out to the second amplifier signal in , wil do this signal gets louder and quieter play with the basremote on the first amplifier ??????
yes my englisch is bad but i try :unsure:
Edited by appi
JBL
I can't tell you with absolute certainty that it will cut them both using the factory remote. Try it and find out.
I can tell you that using the LC1 it will.
Edited by BJD3
DC Level 4 M2 12 D2
Eclipse CD3200
~2 cubes @ 34 hz.
  • Who's Online   0 Members, 1 Anonymous (See full list)
