Help My New Sub Wont Play Loud
Mr Godly
youre hooking your woofer up to your deck
iv already had 2 12" Duals hooked up to it they play fine but the 1500 watt one wont
If its wires in series at 2 ohms, it likely isnt going to work right with that kenwood.
Wire it in parallel to get a 8 ohm load.
What other speakers are connected to the kenwood? What ohm load are they?
im confused with parralell wireing
You have a home theater receiver in your car? Cutting corners won't get you a good result in car audio ever. Just get yourself a proper amp.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
Nate have you always been an admin or is that new?
B5 Passat Build Log
this is in my room i got 2 15"s and 3 12"s i got got this new sub and this one is a high watt then the others and it stops the connection at a certain point on the kenwood
Connect the positive terminal of ONE coil to the negative terminal of the OTHER coil. Then run the POSITIVE from one coil and the NEGATIVE from the other coil out to the amplifier. This will give you a final impedance of 8 ohms at the reciever.
Car audio, home audio, and pro audio are all different things. Home audio receivers are (generally) made for an 8 ohm speaker. Running one at 2 ohms essentially puts the circuit into a protection and it shuts itself off before it hurts itself.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
you need to state out alot more specifics. first off, go ask someone in the "home audio" section.
1999 Monte Carlo
Sony CDX-GT34w
2 Alpine Type R 12"s in 4 cubes tuned to 35hz
American Bass VFL 80.1 amp @ 1 ohm (probably doing between 1000 and 1300rms)
Stock alt, Stock batt, Big 3 Upgrade
Boston s55- 5 1/4s (doors)
Boston s95- 6x9s (rear deck)
Sweet Jesus , fail ,
The thread, or were you talking about my feeble attempt to post the diagrams from 12volt.com?
Okay, this makes more sense. I would go to a place like guitar center and take a look at their amps and Id also recommend a power conditioner.
B5 Passat Build Log
  • Who's Online   0 Members, 0 Anonymous, 1083 Guests (See full list)
