DC Sound Lab
I will soon be the proud owner of a pair of PAI 3000.1 amps and need to know the proper way to wire them up. They will not be linked but instead running at .5 ohm each, one amp per sub. I know that if you were to link them you could run them in master/slave mode and use a single rca to jump between the amps. But since i'm not linking the amps to run them together at 2 ohm, am i still able to jump the rcas in the master/slave fashion or should i just run a rca splitter and a second rca cable to the second amp?
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
Why not strap them then you can use 1 bassknob and only set the master gain I love my amps strapped. Otherwise you have to gain match both amps and lose bassknob
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Like CJ said you should have a output, but yea why not strap the Amps, what vc do you have?
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
they are d1's if ur gunna run each amp @ .5 ohm right?
u would be able to wire them together @ 1 ohm & strap the amps, each amp would see .5 ohm. :drinks:
m_8e0e9deb0e2a020a7ff1bf0d3a6c3306.jpgth_140x100square.jpgth_140x100rev2animated.gifsoundigital.pngth_Banner_140x100.jpgn221468318568_2854.jpg
Correct, dual 1 vc and I guess I could do that, I don't necessarily need a bass knob or mind using two of them lol, but if someone could tell or show how I could properly wire the subs if they were strapped that'd be cool
Currently Own
2 - DC 5k
lvl 4 motor
lvl 2 motor
  • Who's Online   0 Members, 0 Anonymous, 4500 Guests (See full list)
