i hooked up my system and have an AC delco battery just to turn my system on low and make sure everythings right before monday when my XS power battery gets here. I have a 9515 DD and an AQ 2200. I hooked everything up and had it so my amp turned on, but my sub wont play, if i turn it to output master my sub vibrates alittle, but not anything wear its audible. My friend said you have to set the low and high pass phase to like 0 or 180 exactly... or somthing like that....
Everything is hooked up properly.... what do i have to do to get the sub to play? im confused!
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
Audison Bit One processor
Jl-cl-rlc line driver
iPad in dash
Dual Irragi 320a alts
8 batcaps 4000's
Second Skin sound deadened
Are you sure you don't have a coil wired out of phase?
Do you have another amplifier you can try this on?
Edited by BJD3
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
check all wires for contact with the car, for instance, if you got screws that hold in your door trim pieces make sure the screws aren't making contact or drilled through any wires.
i have it wired in parrallel... i dont no about phase stuff lol... it shuld be all good shouldent it? haha and i dont no about the high pass and low pass filters either
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
Set phase to 0.
Set low pass to 70hz.
Set subsonic to just below box tuning.
Make sure sub output on h/u is on and turned up.
Make sure all connections are good and solid.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
What is your LPF and subsonic set at?
subosonic off... and everything is pretty much all the way down, i have never really messsed with a good amp
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
Set phase to 0.
could this be just because mygains are set rong atm?! lol
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
If you have 2v pre-outs you'll want to try and match that to the gain, if the gain on the amp goes to 8v then 2v would be roughly 3/4 of a turn on the gain to get you in the ballpark but i would go to 2/3 to be safe unless you have an o-scope or DD1.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
  • Who's Online   0 Members, 0 Anonymous, 3366 Guests (See full list)
