hi i new at the forums and i need help to get a ecu pin out for the 2JZ-FES ENGINE. CAME IN A TOYOTA CROWN JZS-175. HINT- VEHICLE CHECK ENGINE LIGHT\ BATTERY LIGHT NOT COMING ON METER PANEL. I TRY TO RUN A WIRE TO THE ECU TO THE BATTERY AND BURN THE ECU. I HAVE TO GET BACK A ECU FOR THE CUSTOMER ALSO. COULD YOU ALL HELP ME. THANKS.
yeah uh this is car audio land. not import tuner land. id check with a forum that deals with that engine. or even pick up the manual.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • 1 month later...
you have a blown fuse or short some where ....wtf were you doin trying to connect wires? man that i s a good way to screw some1s car up fast!get a schematic of the wireing and fuse points and go from there fisrt thing you do on a cranks but dont start is check fuse's
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
  • Who's Online   0 Members, 0 Anonymous, 784 Guests (See full list)
