Give me your max dimentions
2006 Dodge Charger
(2) Kinetic 3800
(1) DC Power 270XP
(4) T1-12D4
(1) T2500BDCP
(2) T400.4
7.5 cubic ft.
(2) 6 in ports thru the rear deck
(2) T165.2
(2) T169.3
well im going to get it re measured in the next hour or two soo ill send it then. I do believe it was 15H X 41L X 31W if i remember correctly. I also might change the sub size to an 18 if i can get it in there. also port faced towards the interior if possible
Edited by MatthewBigBossWilliams
15 high but you'd like a front facing 18? I'm confused..
Pioneer AVH-P4300DVD | Hertz 6.5 | Alpine Type R 6x9 | Custom 200A Alt | Knu Flek 1/0 Big 3 and all wiring | Eclipse EA3422 | AudioQue 2200d | DC XL 12 | Red Oak Box ~2.8 cubes @ 30 hz |
He mentioned facing the port forward, not the woofer. So he may want to do sub upward, port forward. Doesn't seem like it would be the best Setup though.
With the dimensions given, I got 9.1 cubes before displacement assuming 3/4" MDF.
where is the best place for that 15 to go then good sir?
I take it it's not the hatchback version, it's the sedan? Get us the max dimensions you can fit in there and someone will help. Do you want it to be in the trunk, facing the back, or in the trunk sealed off? Also, how much power would it be seeing?
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
15H X 41L X 31W and 4200watts RMS
4200w? what amp(s)?
4200w? what amp(s)?
oops my bad 3400. Hifonics Brutus BRZ2400.1D
