Hello all....so with the amount of activity that this site sees I figured I would throw this out there. I have a Kicker ZX1000.1 and the thing is stuck in a cycle of powering up and going into protection mode at about a 2-3 second interval. I have nothing hooked up on the output side as far as speakers and no RCA's. I have around 13.8V input and a good remote turn-on. The amp was working fine the other day and cut out a few times. I just powered down my HU and fired it back up and everything worked fine for a little while. I took the amp apart and cannot find anything burnt up. Anyone have any idea what is wrong with this thing?
have you checked your connections to make sure that you dont have any strands touching on power and ground
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
Yes...I have got the amp taken apart and checked all the connections. It is currently sitting on my test bench hooked up to a test supply. I have 13.7V in on the power and a jumper wire to the remote turn-on. Most everything that I can test with my DMM is dropping a couple of volts when I hear a clicking noise (cannot pinpoint where) and that is when it is going into protection mode. I put another 1000W amp in its place in my car and that works fine. The broken amp doesn't smell like anything is fried and I went over the whole board and cannot find anything burnt up....I don't get it. Maybe some type of thermal protection?!?!
i wouldnt say its a thermal protection. it would be burning hot mostly if it were.
i would say maybe its just defective. im pretty sure the kicker amps are made on a factory line. could quite possibly be just a small piece broken on the board that you didnt notice.
least thats my guess.
Hmmm....Any idea of what to do with it or probably just scrap it?
Might be bad capacitors. I had an amp do the same thing and thats what it was. Or some mosfets went bad and are causing overcurrent protection to trip.
Hammerdown... 1%
idk before you scrap it post some pics of the guts on here. with good detail. maybe some of the more expereienced guys can take a look for you. not doubting you, but some other eyes but your own may help you spot something
Just to be sure... are you using 0 gauge power and ground wire for this amp?
i dont think thatd matter.. unless it calls for 1/0.
dc 1.2k only used 4g and will produce alot of power
Edited by D-train-13k
if your gonna scrap it ill take it :peepwall:
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
  • Who's Online   0 Members, 0 Anonymous, 989 Guests (See full list)
