Amp gets very very hot! (Olympus and SSD 18")
What amp do you have that is 4ch and can run 1ohm ?
2ohm bridged is 1ohm stereo.
I only know of 1 amplifier that is 4ch and can do 1ohm on all channels.
Whats your model number on the bass amp?
hes saying the sub is dual 2 ohm, and that hes bridge his 4 channel to 2 channels, and that hes running 1 channel to one voice coil and the other to the second voice coil, pics of wiring would help a shit ton also state the amp you are using , these things seem minor but help so much
2007 trailblazer lthead unit- pioneer p4300dvd
crescendo ft-1 supertweeters
pioneer m650 pros
audiocontrol 2xs crossover
Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas
says right here...
Bridged, 4 ohms: 400 watts x 2 chan
not 2ohm bridged..
although it does say it will run 1ohm stereo..
kinda weird..
ok.. so..
4 x 125 Watt @ 4 ohms
4 x 200 Watt @ 2 ohms
4 x 250 Watt @ 1 ohm
2 x 400 Watt @ 4 ohms bridge
2 x 500 Watt @ 2 ohms bridge
Fuse: 80A
their goes that idea..
says right here...
not 2ohm bridged..
kinda weird..
This is what the manual sais:
Normal:
125w x 4 on 4ohms
200w x 4 on 2ohms
250w x 4 on 1ohms
Bridged:
400 watts x 2 on 4ohms
500 watts x 2 on 2Ohms
Edit: kk you were faster... I have a 100A fuse in my amp.
its hard to tell witch wires are going where, is it possible that they some how got wired wrong, something like this, not sure if it would matter but it wouldnt hurt to check.
pioneer m650 pros
I thought the same, but I checked it. Everything connected right. (I put yellow tape on the wires for the one coil.)
  • Who's Online   1 Member, 0 Anonymous, 1328 Guests (See full list)
