alright im out finaly using this awesome tool, but i have a question.
first one is when i tested im sub out RCA, trying to find max undistorted volume of my pioneer AVH-P4300DVD
on the 40Hz -15DB, the 40 hz detect signal didnt kick on til 39/40?
is this normal?
ill be using the 40 Hz -10 DB to set my AQ2200D, witch is the only amp in the truck
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
on mine with everything on flat it started to clipint at like 36 on highs and like 38 on lows
then i move the settings around then it made it clip alittle sooner. i got it so it starts clipping or distorting at around 30
beatbox, what sucks on my setup is im using the stock bose mids/highs system, my mids arent that loud at 30 <_<
also you say all your setting arer flat right? are you using the sub volume? i did a few test with it at +6, thats the only thing i have turned up
on a few of the tracks i can go to 40/40 with no distortion... i dk if im doing somethng wrong or what
Sub vol needs to be at +6
use -5 for your highs
And -10 for your subs
is this normal?
For your head unit use the 0db track. gain overlap is set at the amp not the hu.
Helix P SIX DSP
Audiofrog GS10/GS60
Hertz HSV165XL (Rear Fill)
thank you sir :drinks:
not using a highs amp at the moment (stock Bose Mids/highs ftl <_< )
one ? though, i tested my headunit by plugging my RCA straight in the DD-1, when i ran the 40Hz - 10DB track with the sub volume @ +6, the 40Hz detect light didnt come on til vol 29/40 is this normal/ok? just wanna be sure
Edit:
is lt1z323 correct? do i need to use the 40Hz 0db track to find the max clean volume of the headunit, then use the -10Db track when i set my sub amp?
Edited by RickyFriery97
is this normal?
if this is true, when i ran the 0DB 40 hz track i distorted at 32/40
is this normal?
I believe the manual and Steve's demonstration videos will prove I'm correct.
0db for head unit and -10 when setting sub gain
Edited by lt1z323
Helix P SIX DSP
Audiofrog GS10/GS60
