bassrace Posted August 21, 2011 Report Posted August 21, 2011 If its aeros i would tune lower than youu think you want to so you can cut off the pipe as you are tuning till you find a tuning you like the shorter the pipe the higher the tuning. The main thing is that you cant put pipe back on, but you can take it off. Edit: idk about daily use but on the TL those "elbows" to bend the pipe lower your score 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry
Hobbs155 Posted August 21, 2011 Author Report Posted August 21, 2011 Mmm ok, because I read that the port should be one port diameter away from any thing, I think my box my be to shallow to fit a long port. HU: Alpine CDA-9886 with Imprint Module Fronts: Alpine SPR-60C Rears: Alpine SPR-60 Amps: Alpine PDX4.150 and ICE Power 20000D Subs: 1 x 15" Rockford T2D215 Big 3 Upgrade 0/1 AWG 2 Farad Cap Wiring 2 AWG 120Amp ALT
TheyDontWantMusic Posted August 21, 2011 Report Posted August 21, 2011 you didn't say what car you borrowed the 15inch sub from out of. That was a honda civic. honda civic is always going to be louder than a big car.
Hobbs155 Posted August 22, 2011 Author Report Posted August 22, 2011 external: 36cm x 38cm x 96.5cm correct? we don't have 3/4inch MDF in Australia (19mm) we have 18mm. so internal is 32.4 x 34.8 x 45.5 per chamber. meaning each chamber is 51 litre before displacement, which is a bit smaller than I would have done, but should be fine. I'd tune to about 35Hz, as the chambers are smaller than ideal. minimum a single 4inch port per chamber, which needs to be about 36cm long. a 3inch diameter, 3.5inch long port would tune the box to like 45Hz What would you say would be the ideal box for these subs? I have clearly messed up the first enclosure, It looks like putting in a 4" port that is 36cm long, is going to be too close to the back of the box. HU: Alpine CDA-9886 with Imprint Module Fronts: Alpine SPR-60C Rears: Alpine SPR-60 Amps: Alpine PDX4.150 and ICE Power 20000D Subs: 1 x 15" Rockford T2D215 Big 3 Upgrade 0/1 AWG 2 Farad Cap Wiring 2 AWG 120Amp ALT
Hobbs155 Posted August 22, 2011 Author Report Posted August 22, 2011 If its aeros i would tune lower than youu think you want to so you can cut off the pipe as you are tuning till you find a tuning you like the shorter the pipe the higher the tuning. The main thing is that you cant put pipe back on, but you can take it off. Edit: idk about daily use but on the TL those "elbows" to bend the pipe lower your score At the moment i'm trying to use PVC pipe to get the correct lenght and tuning and then go out and buy proper aeros and cut them to the correct size. Do you think i'm going wrong here? HU: Alpine CDA-9886 with Imprint Module Fronts: Alpine SPR-60C Rears: Alpine SPR-60 Amps: Alpine PDX4.150 and ICE Power 20000D Subs: 1 x 15" Rockford T2D215 Big 3 Upgrade 0/1 AWG 2 Farad Cap Wiring 2 AWG 120Amp ALT
Hobbs155 Posted August 22, 2011 Author Report Posted August 22, 2011 Here is a photo of the box I was supposed to put up a while ago, still need to take a photo of the amp. https://skydrive.live.com/?sc=photos&cid=f379b6a511559622#!/?cid=f379b6a511559622&sc=photos&uc=1&id=F379B6A511559622!192!cid=F379B6A511559622&id=F379B6A511559622!197&sc=photos HU: Alpine CDA-9886 with Imprint Module Fronts: Alpine SPR-60C Rears: Alpine SPR-60 Amps: Alpine PDX4.150 and ICE Power 20000D Subs: 1 x 15" Rockford T2D215 Big 3 Upgrade 0/1 AWG 2 Farad Cap Wiring 2 AWG 120Amp ALT
bassrace Posted August 22, 2011 Report Posted August 22, 2011 No you only have 2.99 sq in of port per cu ft . You need between 9-12 sq in of port. Youll prob need 3-4 ports. Ill put your dimensions in torres when i get home in a min. Im mobile rite now 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry
bassrace Posted August 22, 2011 Report Posted August 22, 2011 Is there any way to let some of your ports be external? That seems like the only way to make it happen. 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry
Hobbs155 Posted August 22, 2011 Author Report Posted August 22, 2011 Ok, heres the photos for the amp i was supposed to upload last week. https://skydrive.live.com/?sc=photos&cid=f379b6a511559622#!/?cid=f379b6a511559622&sc=photos&uc=1&id=F379B6A511559622!192 HU: Alpine CDA-9886 with Imprint Module Fronts: Alpine SPR-60C Rears: Alpine SPR-60 Amps: Alpine PDX4.150 and ICE Power 20000D Subs: 1 x 15" Rockford T2D215 Big 3 Upgrade 0/1 AWG 2 Farad Cap Wiring 2 AWG 120Amp ALT
sayhuh? Posted August 22, 2011 Report Posted August 22, 2011 You have too many power cables hooked up Still having the same problem? Blown
