whatsepultra Posted August 19, 2011 Report Posted August 19, 2011 alright i have a 92 prelude with two fosgate t1 12s there in the vehicle facing foward behind the front seats where the back seats used to be my problem is when i close my trunk i lose alot of output. when its open its great loud deep and clean but as soon as i close it theres a drastic drop in sound pressure what the hell is going on. just a lil info here its two t1 12s in 5 cubes slot ported at 38hz running off 2100 rms ill post pics here in a min if itll help. oh theres no bracing or dividers between the trunk and vehicle cabin but subs are facing foward not towards the rear so i need help to find a solution to this problem any help would be great......thanks well here are the pics they suck cause it was dark out but you get the idea
OrionStang Posted August 19, 2011 Report Posted August 19, 2011 Turn the box around or seal off around the box. I sealed mine off (subs forward) and its a lot louder. SMD Super Seller My Feedback Thread
ChevyBoy95 Posted August 19, 2011 Report Posted August 19, 2011 alright i have a 92 prelude with two fosgate t1 12s there in the vehicle facing foward behind the front seats where the back seats used to be my problem is when i close my trunk i lose alot of output. when its open its great loud deep and clean but as soon as i close it theres a drastic drop in sound pressure what the hell is going on. just a lil info here its two t1 12s in 5 cubes slot ported at 38hz running off 2100 rms ill post pics here in a min if itll help. oh theres no bracing or dividers between the trunk and vehicle cabin but subs are facing foward not towards the rear so i need help to find a solution to this problem any help would be great......thanks you know how when you roll your windows down it sounds louder? its the same concept. When everything is closed up it is pressurizing the cabin but when the windows are down or the trunk is open, the environment around the subs change allowing them to move more freely because of the zero pressure environment, causing more air movement, and what our ears perceive as loudness to change. and x2 on orionstang, sealing it off will help a lot. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
keepinitloud Posted August 19, 2011 Report Posted August 19, 2011 if you want to fire them forward your going to have to seal them off from the trunk or turn them around 06 chrysler 300C Hemi one mmatts dreadnaut 15 powered by a planet audio vx 2200d fosgate p200 running planet audio 8" midbass drivers and super compression tweeters stock battery and a stinger spv44 Irragi 300 amp alternator big 3 1/0 http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
whatsepultra Posted August 19, 2011 Author Report Posted August 19, 2011 would walling it off help???
OrionStang Posted August 19, 2011 Report Posted August 19, 2011 If its done right. You don't want any air/sound getting behind the wall. SMD Super Seller My Feedback Thread
