superdave07 Posted August 20, 2011 Report Posted August 20, 2011 Ok, Heres me problem. In my daily driver (95 integra) This only happens some times. But when im at or near full tilt, my amp will shut off. Only seems to happen during higher freq. notes. Voltage does not drop below 13.0 volts. Its a db drive platinum 2000.1d wired at 1ohm before rise. Ive had this amp at .33 before with not trouble at all. The amp has not had a lot of tuning with this set up. But gain is at about 30% and the rest should be pretty close. Head unit is an Alpine IVA-W200. Anyways, maybe im overlooking something here but i cant seem to figure it out? Any ideas? something to try? Someone please throw me a bone lol FYI subs are 2 DC lvl3 15s, dual 4ohm. Not dropping voltage, not getting hot. turn it off, wait five seconds, it will come back on. And this only happens every so often... Thanks in advance!!!! Xterra * 69 Camaro * Audi S5 36 Ford * 51 Mercury looking for wire sponsor www.flyracing.com
dwright27 Posted August 20, 2011 Report Posted August 20, 2011 tuning frequency? 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
superdave07 Posted August 20, 2011 Author Report Posted August 20, 2011 The box is tuned to 32. Ill go look at the amp real fast im not exactly sure where its set. I mean it may just be that my setting are not close at all. But Ive had this set up in the car for a few weeks and not had any issues until a few days ago. I thought maybe it was just the temp outside? but all three times this has happened it was at night. And maybe 80 outside... Xterra * 69 Camaro * Audi S5 36 Ford * 51 Mercury looking for wire sponsor www.flyracing.com
kickass audio Posted August 20, 2011 Report Posted August 20, 2011 Sorry if you or anyone considers this a post dump. This may be the amp shutting off from a overload. I had that before on my one amp and it was wired at a load twice than the lowest imp load it was made to handle but when a really high note hit it went into protect for a second and came back. Mine would keep cutting in and out at high bass notes. IDK what it was but i got a new amp and it never happened again but i measured the current it was drawing and it was more than the amp was made to draw for some reason. Another thing to check would be your impedance of your subs to make sure they are fine. I also had a sub where i busted the wire apart on one coil but it kept playing. If i had a song with a lot of excursion the loose voice coil wire would short out and make the amp protect and them come back when i turned it off and back on. It didnt have any coil rub or anything so take out the subs and look at them carefully to see if anything is out of place. edit: where are your amps mounted? 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
