Amp Guts Thread
TRTC360
  • 3 weeks later...
Picked this 08ZX700.5 up for 20$ since Amp 2 and the sub amp are fried Kicker said it looks like water damage. Still haven't sent in in for repair.
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
  • 3 months later...
My dd m80 pretty beefy fugger for a 800 watt amp its crazy efficient too i have less voltage drop than i did with my boss "1200" watt amp
My setup,
Digital Designs M80
3 Re audio 10's ported tuned to 36 hz
Kenwood x-696
SHCA 0 gauge
Polk audio coax running off hu
  • 8 months later...
Orion XTR2200.1d
I absolutely LOVED this amp, can't beat its big brother (orion xtr3700.1d) NEW for the price, $599!!!
Current System
Deck:
Pioneer DEH-80PRS (3-WAY ACTIVE)
Incriminator Audio 3.4 4 Channel (75x4 @4 ohm)
(2) NVX X-Series Active Tweeters
(2) SB Acoustics SB16PFC25-8 6" 8 ohm Paper Cone Woofers
Subs:
(2) Sundown Audio SA-12's
Amp:
(1) Kicker CX 1800.l (43CXA1800.1) 2016 Model
(It is rated 1800 @2 ohm but I have it running at 1 ohm, does a little over 2500!)
Big 3 w/ 1/0 gauge wire
(1) XS Power D4800 under the hood
(1) Duracell Group 31 Deep Cycle
(4) Runs of KnuKonceptz Kolossus Fleks Kable (2 pos, 2 neg)
(1) KONfused 4-way Power and Ground Block
Alternator:
DC Power XP 270 High Output
  • 6 months later...
Orion XTR2200.1d
I wondering my Brz2400 amp was sold and thought maybe I try the XTR2200.1D Fi 18 might like it. Little smaller foot print, but ratings at 12.6 volts etc., seems like a good option, any thoughts welcomed.
  • 7 months later...
Man, i'm resurrecting this thread, surprised its not pinned, and more posts! Sheesh!
MERICA'
Soundstream going on a coax set in my 91 fox coupe, Already has alpine coax's front & rear, Going do use the HCCA225 on an Orion 15" SVC4 HT2 in a ported box in the trunk firing forward. Keeping everything somewhat old school ish.
11350488_10153362047103540_333804371494511390188_10153362047138540_1650177635311
22400_10153362047163540_8283966411561712
10421326_10153362047203540_4433850500990
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
  • 5 months later...
MERICA'
11350488_10153362047103540_333804371494511390188_10153362047138540_1650177635311I wondered what you guys think about soundqueb or hd subs, not asking or putting one down just if one might hit lower then other also on amps found this out:
BRZ 2400 HiFonic
Uncertified
2 ohm– 1,080 12.48 Volts 1.6 ohm-1,275-12.25 Volts 1 ohm-1,494
Certified
2 ohm-776 12.48 Volts-12.8 Volts 1.6 ohm-908-12.29 Volts 1 ohm-1,113-12.8 Volts
Dynamic
2 ohm-1,325-13.5 Volts 1.6 ohm-1531 1 ohm-2,055, 2,109 Best could get dynamic
SoundQubed Q1-2200
Certified - 1 ohm 1,149
Uncertified - 1 ohm 1,463
Dynamic – 1 ohm 2,124
These amps have certified power not just dynamic power of the above matching their rated outputs. Above board inside look the same power supply etc below best
Cresendo S1500.1
Certified 1 ohm 1,762 13.9 volts Uncertified 1 ohm 1,798 Dynamic 1 ohm 1,892-14.4
Cresendo BC 2000D
Certified 1 ohm-2,103 2 ohm-1,382 4 ohm-807
Uncertified 1 ohm-2,238-13.67 2 ohm-1,439-14 4 ohm-836-14.3
Dynamic 1 ohm-2,778-14.4
10421326_10153362047203540_4433850500990Guess my question is if an amp does rated power certified, uncertified and dynamic would it not play sub better then one that only hits even if slightly higher its rating at its dynamic rating which to me seems miss leading to most users unaware of this issue. Most of US buyers I would assume. Cresendo and higher end, guess from these ratings I could see why their better choice.Above in case high lighted are not viewable first was brz 2400 soundqubed Q1-2200 vs Cresendo, not as offense just so newbies etc. get facts is this not what all this is about. Would not an amp that does all specs from certified to dynamic play more consistent?
  • Who's Online   0 Members, 0 Anonymous, 1824 Guests (See full list)
