Amp Guts Thread
TRTC360
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
  • 4 weeks later...
let's get some moar amp porn in here!
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
Visonik V2908
2-channel amplifier
Total peak power: 2400 watts
RMS power:
2 ohms: 850 watts x 2 channels
4 ohms: 600 watts x 2 channels
4 ohms bridged: 1200 watts x 1 channels
Signal/noise ratio: >90dB
Channel separation: >60dB
Frequency response +/-0.5dB: 20 - 20kHz
Crossover frequency:
Low pass filter: 40 - 250Hz
High pass filter: 150 Hz
Bass boost: 45Hz 6dB
Fuse: 50A x 2
Dimensions (WxHxD): 12.20" x 2.17" x 39.37"
Next to a 1500rms amp
How many 1200rms amps look like this
- 1998 Ford Mustang -
Time to rebuild.
4 15s and alot of power
TEAM DTF
Amp Name:
Stetsom 14k2d
Specs:
FEATURES V 14K2 D - 1 Ohm
Number of Channels: 1
WRMS Power (1 ohm) to 13.8 V: 16.200 Watts
WRMS Power (2 ohms) to 13.8 V: 11.200 Watts
WRMS power (4 ohms) to 13.8 V: 5.300 Watts
WRMS Power (1 ohm) to 12.6 V: 14.200 Watts
WRMS Power (2 ohms) to 12.6 V: 8.050 Watts
WRMS power (4 ohms) to 12.6 V: 4.350 Watts
Supply voltage: 9 to 15V
Pictures (required):
Time to rebuild.
TEAM DTF
Amp Name:
Digital Designs DD Z2 LV
Specs:
8350W x 1ch @ 14.4v
Time to rebuild.
TEAM DTF
Amp Name:
Specs:
1500x1@4ohms - 14.4v
6000x1@1ohm - 14.4v
8000x1@1ohm - 18v
Dimensions
32 L x 12 W x 2.76 H
Weight
56 lbs
Time to rebuild.
TEAM DTF
thats all i got for now. I will try to get pictures of my D9 one of these days
Time to rebuild.
TEAM DTF
damn Rob thanks for those pics you have some beast amps right there :D
  • Who's Online   1 Member, 0 Anonymous, 19071 Guests (See full list)
