DC Sound Lab
i have noticed at low volume i get a scratching sound with like listening to the radio when people talk, i dont think it is coil rub(not sure though) because when its beatin down i dont hear anything. Its almost like a growl(with the voices but i havent heard it during music) but i know it isnt alt noise or ground noise. Im wondering if it is my amps or because im using splitters... but idk. Both coils read 1.0 flat and it is a dual 1. any insight? i maybe can pick it up on vid tomorrow. I have had the sub for about 12 hours, and has 10min of play time. its a level 5 18.
here is the video, skip to 5minutes exactly to see the noise, the first part is a trick i used for the first time to get my sub out. coil looks weird, off to DC it goes :badmood2:
Edited by ChevyBoy95
Does it sound like a static noise?
no, it doesnt sound like static or interference.
the hu is a apline cde-125bt and it has 1 set of preouts (2v)
maybe its out of alignment
i was thinking that, but if there was rub wouldnt it get louder as the sub moved more? when i turn it up and the bass gets loud i cant hear it anymore (obviously).
is it like a click or a poping if so it could be a bad channel on your amp or your ground is not all the way 100% good try sanding your ground to get a 100% good contact or it could be a rca out grounding issue on your hu
not clicking or popping (99% sure, last time i listed to it was 8hrs ago), amps are grounded to a battery (Hc800). But it might be the RCA issue. Ill try and get a vid of what it sounds like to get a better idea. But that will be in about 10hrs.
im just trowing out ideas but hopefully you can get a good 100% diagnosis of what it sounds like or is and can get it fixed
My Build:Blazer Got Bass
yea, ill clamp the outputs separately of each amp, ill pull the deck out and check the RCA connection, maybe its loose or something. I need to check the wires connecting to the sub, etc. Ill go through a wiring check after i get out of class.
