Ok I am wanting some new subs. Its between b-stock sundown 12 or obsidian 12. Both subs are d2 config. I am wanting 2. I'm also buying a saz2500 and a mechman alt.
So basically which would be the best bet. Any help would be appreciated
2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette
2003 corvette z06
alpine radio and the bose system that came stock
Another question is a 220 amp alt enough for the 2500 amp
2003 corvette z06
I would say the alt would be sufficient. What batts do you plan on running? How many? What model subs?
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
Either sub is amazing! PM me tho if you decide on the obsidians tho ;)
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
My uncle can get some batteries like yellow tops. Can get three or four til I get enough money for xs. And kam will do.
2003 corvette z06
Why getting two D2 subs? You'll only be able to wire to 8, 2, or .5 ohms. You should be getting D4s, so you can wire to 1 ohm.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
The only options are d2.
2003 corvette z06
D4 Obsidians would be cheaper, as you would have to pay full price for the SA's to get D4s then. You'd probably be just as happy with the Obsidians, but I'm just not sure if they are as rugged as the Sundown SA's are.
My Saab 9000 build
Well wired to two ohms that amp is rated at 1200 rms. Which is perfect for em.
2003 corvette z06
Yes, but what is the point of getting a high output alternator for only 1200 watts? If you have the power, you might as well be able to have it on tap. You don't need to give them 2500 watts just because your amp can put out that much power, but it's sure nice to know that you can give them a little more without worrying about clipping them. Just be easy on the gain and you'd be good to go.
My Saab 9000 build
  • Who's Online   0 Members, 0 Anonymous, 2422 Guests (See full list)
