Box size for a 15" SMD
chrishova
I have a 15" SMD on a SAZ3500D in a 4 cu. ft. box 3.5net after port tuned to 29htz.. I like it, but I need to make another stronger box with more, stronger screws and stronger caulk, so I was wondering if anybody has or had a better formula for a SMD. I only have about 4 cubes net. It is a daily, but I obliviously don't mind the banging!
(I did try to search before I made this post, no luck) THANK YALL!!! :popcorn:
for only 15 bucks nd acouple of simple questions ray can give you a nice box design :drinks:
Torres? Wow, that's not as much as I thought it would be! Thank you
no i never once mention torres why would u bring that up i say said ray he us doing box designs for a good price
Ray WHO?!?!
Pontiac Grand Prix GT
400a Mean Machine alt.
EIGHT DD 12''s on a DDz2
DD vo 8''s,6''s,5.25''s&tweets
Norfolk, VA
http://www.youtube.c...ser/ovnorfolkva
https://www.facebook.com/groups/TheSPLSpot/473815915987218/?notif_t=group_activity#!/chrishova
http://www.stevemead...__fromsearch__1[/color]
What kind of glue did you use to glue the box together?
I think Liquid Nails or something crazy that bonds anything to anything, I do rember spending like an hour looking at the different kinds of stuff!
Norfolk, VA
are you positive it's the box making the squeaking noise? nice terminals on your battery, where did you get them?
Yea, I had this sound before and took the box apart and saw screws broken in half.
audioanonymous Makes theese! He's a member here , tell him I sent ya! Those are the BA-60, (six 0 gauge inputs), he makes all kinds of stuff, buss bars, etc!
Norfolk, VA
These are the BA-60's from audioanonymous ! He makes all kinds of stuff!
Norfolk, VA
The AA website says 2-4 cu. ft., I have a 4 cu ft. box 3.5 net with port tuned to 29htz., all the SMD's I have seen look like they are in smaller boxes, I like mine, but I gotta redo it anyway, I got a little water on a corner (Thanks, Irene). Anybody have a good sweetspot?!?!
Norfolk, VA
Well, I just did an install for an SMD 15. Its in 4 cubes tuned to 31 hertz (the sketchup file is on my desktop comp back in the states) so I don't recall how much port area. Its only seeing about 2k at 4ohm from an AP30001d and it does hairtricks like cake (should do a lot better on a DC 5k :ph34r: ). Sub forward port forward and completely sealed off from the trunk. This is the only vid he has up, I'll yell at him to make some more.
It's all gone!
The Celica Build
Feedback
If I buy something from you, DO NOT USE FEDEX!
Nice! That's about what I'm at, 4cu ft . - port area = about 3.50 cu ft, tuned to about 30htz also! And I'm running my SAZ3500D at 2 ohms so I got about 1800+ watts! Port forward, sub forward also... I do like it! but almost all other pics of this sub looks like its been in a smaller box...
I can't wait for my alt. to come in so I can wire this thing to 1 ohm and get 3600+ watts to it!!!
Norfolk, VA
Just curious, how much port area do you have...
And how do you plan to wire down to 1ohm if your wired at 2ohm right now?
I have a SAZ3500D and 4 wires going from the amp to the speaker (SMD D2), 1 from each pos on the amp to each pos terminal on the speaker, and the same with the negs. I asked around and a few people said it would be 1 ohm, so I clamped the one pos and it was 980watts and came to 4 ohms, so I figured 1800+ at 2 ohms. I only found 10 gauge wire to run as speaker wires. I will try to reclamp it again... This is working for right now because I am waiting on a bigger alt., but my rebuilt alt holds it to no lower than 13v.! (WITHOUT THE VOLT BOOSTER! I took it off because I saw somewhere the XS batts shouldn't charge higher than 14.4). And I my sub IS breaking in, getting louder everyday! My alt should be here soon and I will try to wire it like this 1_2ohmDVC_1ohm.gif
Norfolk, VA
Anybody with some SMD box recommendations?!?!?
Norfolk, VA
  • Who's Online   0 Members, 0 Anonymous, 941 Guests (See full list)
