Box size for a 15" SMD
chrishova
I have a 15" SMD on a SAZ3500D in a 4 cu. ft. box 3.5net after port tuned to 29htz.. I like it, but I need to make another stronger box with more, stronger screws and stronger caulk, so I was wondering if anybody has or had a better formula for a SMD. I only have about 4 cubes net. It is a daily, but I obliviously don't mind the banging!
(I did try to search before I made this post, no luck) THANK YALL!!! :popcorn:
Pontiac Grand Prix GT
400a Mean Machine alt.
EIGHT DD 12''s on a DDz2
DD vo 8''s,6''s,5.25''s&tweets
Norfolk, VA
http://www.youtube.c...ser/ovnorfolkva
https://www.facebook.com/groups/TheSPLSpot/473815915987218/?notif_t=group_activity#!/chrishova
http://www.stevemead...__fromsearch__1[/color]
for only 15 bucks nd acouple of simple questions ray can give you a nice box design :drinks:
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Torres? Wow, that's not as much as I thought it would be! Thank you
Norfolk, VA
I was just wondering if anybody runnin these woofers found a sweet spot. The spec. sheet says 2-4 cu. ft.....
Norfolk, VA
Stronger caulk and screws? That shouldn't be what needs improving. In fact, caulk has no real use in sub boxes and screws provide more of a clamp for when the glue is setting up, no real strength. Can I see your box? I have a feeling its the victim of improper assembly. When I want to make a stronger box, I tend to up the baffle thickness and brace areas that will need it.
It's all gone!
The Celica Build
Feedback
If I buy something from you, DO NOT USE FEDEX!
I don't have a pic of it being assembled , I did use 2 sheets for the front baffle, as well as 2 sheets for the back. I am starting to hear squeaking noise where the screws snapped and the broken pieces are rubbing together. I had this before. I use drywall screws, the black ones, and alot of them, predrill my holes. I even ran 2x4's inside for bracing. There's a glimpse of my box on my youtube.
Norfolk, VA
no i never once mention torres why would u bring that up i say said ray he us doing box designs for a good price
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Use Titebond II or some industrial grade subfloor adhesive, it works great. And screw are important, since in high power setups they keep the MDF from peeling back that layer right where it's glued at.
Ryan Miskin - owner of RAM Designs
I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script>
2200+ designs since March 2011...
  • Who's Online   0 Members, 0 Anonymous, 847 Guests (See full list)
