what up guys so im kinda new to this im doing it on my own (no friends are into it like me) this last winter i bought a 04 Malibu maxx hatch back specificaly for subs because i read up on it and heard that hatchbacks are the way to go for loud bass so i then got a pair of poss phantom 12's and gave them there own 1500 watt boss phantom amp (more like 300 watts) but anyways i just wanted some cheap stuff so i could learn and play and not really worry about it but any who just officaly sold them today in a 4th order sounded decent but i want MOREE so im thinking ill move up a notch and run 2 obsidian audio 15d2 wired down to 1 ohm apiece at like 800 to 1000 watts rms in a custom box about 4ft^3 per sub at about 35 hz what u guys think would that be a good next step? by the way big 3 done and extra batt going to be incorporated i have done alot of homework
well its good that your doing your homework. Sounds like a decent little setup. dont cheap out on a amp. get something that will do rated RMS and you will be happy.
My youtube channel, please subscribe
http://www.youtube.com/ballinblaza
Are you wanting to run 2 separate amps at 1 ohm, or run 1 at .5ohms? Probably be better off to just get 2 D4's and run them at 1 ohm off of something like an AQ2200D or something.
Don't cheap out on electrical though. Atleast a good battery in the back, with some 1/0 and the big 3 done in 1/0.
-Zach-
2010 Toyota Tundra
Full Hybrid Audio SQ
7" BDS on 37's
2000 Ford Expedition
160+ dB Green Turd -SOLD- :(
yea of course done in 1/0 sorry i should of put that and all wiring will be done in that i kinda planed on 2 amps but now that i really sit and think about it ur right dual 4's would be better less strain on my alt ... i plan i replacing that too at some point but school has to take top priority for money right now once im makine 80$ an hr flying ill buy what ever it is i want for subs lol but yea i plan on getting a good amp that i can transfer form system to system for sure
$80 an hour flying? what will you be flying?
if you get dual 4's, just run an amp that outputs about 1200wrms at 1 ohm (audioque 1200d for example) and you should be fine. do the big 3 in 1/0 gauge and you will be set.
yea but i want to run like 1000 rms CLEAN to each sub
even though i dont recommend it, go with an aq2200d then.
edit: but then you will more than likely need to run an AGM battery in the rear along with possibly a new alternator (depending on how big your stock one is)
Edited by Kranny
